dyna 2000i ign : V-Twin Forum: Harley Davidson Forums
Old 01-22-2012, 09:28 AM   #1 (permalink)
john365 is on a distinguished road
dyna 2000i ign
anyone ever had one?i am not getting any spark to the plugs.have power to coil.bike cranked the last time and ran fine.now will not fire.tired of motorcycle pms(parked motorcycle syndrom)
john365 is offline   Reply With Quote
Old 01-22-2012, 10:59 AM   #2 (permalink)
Acquisitions
dynageno's Avatar
dynageno is on a distinguished road
Have one in the Shovelhead. Works good!
What kind of bike and year is yours?
Back in Black
dynageno is offline   Reply With Quote
Old 01-22-2012, 06:37 PM   #3 (permalink)
softail,home built 84-99
Old 01-22-2012, 06:47 PM   #4 (permalink)
LowRiderCustom is on a distinguished road
If there's power to the coil and no spark the coil is bad.
LowRiderCustom is offline   Reply With Quote
Old 01-22-2012, 07:17 PM   #5 (permalink)
tussuck's Avatar
tussuck is on a distinguished road
Try checking the voltage output on the ignition. I am talking about the wire that goes to the coil/s.
Normally that should be held up at +12volts and then to fire the coil the ignition pulls it to earth really quickly and then raises it back to +12volts.
If its got voltage then I would be looking at the coil. If it has no voltage then I would be looking at the ignition. Are you sure that the ignition has its +12volt power feed okay?
Just my thoughts....
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote
Old 01-23-2012, 01:50 PM   #6 (permalink)
thanks was already thinking along thoes lines.yes it has power to the coil and ing.has power to it.will check voltage.
Old 01-23-2012, 01:55 PM   #7 (permalink)
sgmfisher is on a distinguished road
Are you running original ignition or has it been converted to points?? Pickup on the original could be bad. In the wind.
Pops
sgmfisher is offline   Reply With Quote
Old 01-23-2012, 03:22 PM   #8 (permalink)
4XLT's Avatar
4XLT is on a distinguished road
its a good ignition, have had mine in for over 3 years with my build and not one problem!
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
Vance & Hines Pro Pipe
4XLT is offline   Reply With Quote
Old 01-24-2012, 10:13 AM   #9 (permalink)
cernunos is on a distinguished road
Halloo. Angel has a Dyna 2000i in her. The unit took a crap after about a month's riding this past fall. If the unit is the "nose-cone" type then check to see that the red LED indicator is flashing while cranking over. Dyna sent me a new unit within five business days. Still thinking of going back to points...never had points leave me stranded.
C.......
cernunos is offline   Reply With Quote
Old 01-28-2012, 06:38 PM   #10 (permalink)
yeah points sounding better all the time,got a few things to try then it comes out and goes back to dyna
Old 01-30-2012, 12:51 PM   #11 (permalink)
wanna ride's Avatar
wanna ride is on a distinguished road
When I bought my dyna2ki kit the coil went bad after a bit, I linped home on one cyclinder and temporarily replaced coil with my old stock coil and switched to dual fire. I bought a single fire crane coil and all has been well. I carry the stock coil in my tool pouch.
1989 FLHTP
http://www.youtube.com/watch?v=qMsvTAfoqiw
1989 Heritage
Lynn
wanna ride is offline   Reply With Quote
