thanks pulidog830.. i am have trouble finding neutral.
strokerjlk
So this could be a bigger problem. "the crankcase then you could have a output shaft leaking motor oil into your primary". how or what needs to be done to fix this problem. i had the top and bottom end rebuild about 18000 miles ago and now this. the shop i took it to will not see me again,
they were a indy shop that i went to had a good rep, but have three friends after me have major issue with them.
also what will it take to fix this issue if it is this,then there is the problem that the evo's during your era had with the case weeping oil into the primary.
