Custom DynamicsCycleGear.comSportbikeTrackGear
Pro PadAdvanstarMotorcycleShowsFuel MotoAmerican Side Road CycleJardineProducts.comMotorcycle.com Classifieds!
Old 11-02-2009, 07:02 PM   #1 (permalink)
hbmc's Avatar
rubber oil lines
Been looking for new lines as mine are old and the clamps are not getting it tight enough. seeping at the hose end (just one) Was wondering about if I can use oil line from NAPA auto ?? But I am concerned about the 90 degree bends in the line and if it is not already been shaped/ bent in a 90---will I get a collapse at the bend spots? I have only found a set for about 150, for 10 feet of line. Thanks for looking in
Regards
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
Old 11-02-2009, 08:49 PM   #2 (permalink)
I use the rubber hose made by Goodyear, from NAPA. Don`t make the bends too tight and you won`t have any problems.
Old 11-02-2009, 08:55 PM   #3 (permalink)
hbmc's Avatar
That is what I was thinking I was just double guessing cause of the heat of the oil and was wondering if anyone is as thrifty as I when it comes to dropping to 15 dollars a foot for everyone else's version.. if they are running it and what to watch out for. Thanks Dan
1991 flstf 'fat-boy
2-1 White "E-pipe"
Old 11-03-2009, 05:50 PM   #4 (permalink)
The Goodyear hose that I use is SAE 30R7.
