Originally Posted by econnor
.....The side by side comparisons on the engine side of these sensors is very interesting. The older (-83) sensor has one sensor point on the back. While the newer ones have 2 sensor points.....
This being the case, and not having them in front of me to compare, the one with one sensor would have a cup with 2 cutouts. Each cutout would represent the firing of the cylinder at the correct time. The one with 2 sensors would have a cup with only one cutout and would fire the cylinders based on the sensor. Both systems are a dual fire system and fired both cylinders every time.
If I am not mistaken, the -83 was optical based (used a light in the sensor).
This is all speculation of course, not having tested them to confirm but I do I have a fair amount of background in cone engine style ignition modules and design.
