Old 10-29-2009, 03:34 PM   #1 (permalink)
harley97 is on a distinguished road
Primary drain plug leaking
I have a 97 Dyna Wide Glide. The drain plug on the primary is leaking. I have replaced the plug and the o ring and also put pipe tape on it in an attempt to stop the leak. Is there any other way to stop this leak? Does anybody make a bigger drain plug? The one in it is the tapered type plug.
harley97 is offline   Reply With Quote
Old 11-02-2009, 11:13 PM   #2 (permalink)
brscott73 is on a distinguished road
I have a 1992 EVO. I use white 'thread sealant' that comes in a small tube and apply a small amount around the threads. I have never had a leak or any other issues with the primary case whenever I do a fluid change.
-Br-
brscott73 is offline   Reply With Quote
Old 11-02-2009, 11:40 PM   #3 (permalink)
JustDave71's Avatar
JustDave71 is an unknown quantity at this point
any chance you have a crack near the hole? mine's got a tiny crack so it drips just a little. my gasket weeps in a few spots too...
JustDave71 is offline   Reply With Quote
Old 11-03-2009, 07:15 AM   #4 (permalink)
Retired Navy - MCPO
Ed Y's Avatar
Use "thread sealant with Teflon" as another poster stated. Not sure what you mean by O-ring. It's a pipe threaded plug, didn't come with an O-ring and shouldn't have an O-ring on it.
They are cheap. I always replace the plug after approx 3-4 times in and out.
And don't tighten them too much. Being pipe plugs, you will eventually ruin the fit by screwing them in to far. There should be about 1/16 to 1/8" protruding.
Ed Y
2002 FLTRI
I yam what I yam.
