Bub EnterprisesJekillandHyde.euMotorcycle.comSportbikeTrackGearMBO EnterprisesCustom Dynamics
ProCharger.comDiamond Bar Choppers
Old 10-17-2009, 10:38 AM   #1 (permalink)
ANTLERMAN is on a distinguished road
motor hiccupp
I have a 1997 dyna wide glide w/ 36k miles all stock except for sampson pipes. Motor hiccupps when giving throttle even after warming up. It has been recommended that I re-jet carb and get high flow air system. Any suggestions??
ANTLERMAN is offline   Reply With Quote
Old 10-17-2009, 11:43 AM   #2 (permalink)
trimmer is on a distinguished road
Always have someone read your plugs before doing anything.Sounds more like an air/fuel mixture issue than jetting if you're all stock except for the pipes.High flow air cleaner is always a good idea.
trimmer is offline   Reply With Quote
Old 10-17-2009, 11:46 AM   #3 (permalink)
SAMCRO is on a distinguished road
rejet and airfilter should do it. But read the plugs first ofcourse.
SAMCRO is offline   Reply With Quote
Old 10-17-2009, 02:05 PM   #4 (permalink)
blackjackcustms is on a distinguished road
Check for intake leaks. That's not very many miles for a 97, and when they sit, the intake seals love to dry out and crack.
That being said, the Highflow AC will give you more gains than the pipes did, and ALL CVs need to be tweaked.
blackjackcustms is offline   Reply With Quote
Old 10-17-2009, 03:20 PM   #5 (permalink)
ironheadbuck's Avatar
ironheadbuck is on a distinguished road
i had a little problem i couldnt figger out with mine - screwed in idle mixture screw real gentle -counted turns-turned it all the way back out -took a can of carb cleaner and sprayed thru hole -used a lot of can -replaced screw -runs like new -worth a try -cheep -ps sorry i have a mikuni 45 -lol
02 roadking-lv it
73 xlch
07ducati 1098s
trek 6500
no helmet or training wheels
ironheadbuck is offline   Reply With Quote
Old 10-17-2009, 03:34 PM   #6 (permalink)
I haven't seen your bird.
MadCity's Avatar
MadCity is on a distinguished road
I had to have my intake seals changed last week, and the symptom the bike was exhibiting was a hiccupping motor at full operating temperature. Had the seals replaced — no more hiccups.
03 XL1200 Custom
MadCity is online now   Reply With Quote
Old 10-17-2009, 08:05 PM   #7 (permalink)
gsxrboy96's Avatar
spray some carb cleaner around the intake seals to see if the idle changes at all, if it does, thats a easy fix with new seals, also these evos came from the factory lean...and i mean very lean, fatten the bike up anyway, such as a 45 pilot, the bike will run cooler and better, guranteed !
gsxrboy96 is online now   Reply With Quote
