AdvanstarMotorcycleShowsRRcycles.comAmerican Side Road CycleCustom DynamicsCycleGear.comMotorcycle-Communication
ProCharger.comJardineProducts.comBub Enterprises
Old 10-14-2009, 11:14 AM   #1 (permalink)
bigbadal's Avatar
bigbadal is on a distinguished road
compression
Who knows how to figue out the ratio for compression?? I have 174lbs in each cylinder on a stock 80" evo. That's with both plugs out, in nuetral and the carb wide open. What would be my compression ratio?? Alan
bigbadal is online now   Reply With Quote
Old 10-15-2009, 11:33 PM   #2 (permalink)
gsxrboy96's Avatar
Its hard to say, I know with 10 to 1 my bike was 190lbs.
Old 10-16-2009, 07:23 AM   #3 (permalink)
93 FXR's Avatar
93 FXR is on a distinguished road
I believe that the stock compression ratio on an Evo motor is 8.5:1.
______________________
80" EVO, .020 over, 9.7:1
Keith Black Pistons
Ness Big Sucker
CV w/ DynoJet Kit
Screamin' Eagle Ignition
Screamin' Eagle Heads
V-Thunder 3030 Cam
Sifton Lifters
Crane Adjustable Pushrods
Carlini Torque Arm
Custom Porker Pipes
_______________________
93 FXR is online now   Reply With Quote
Old 10-16-2009, 10:28 AM   #4 (permalink)
mooooving out!
route66paul's Avatar
what cam is in the engine?
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 10-16-2009, 11:50 AM   #5 (permalink)
bigbadal's Avatar
Yes, I believe that is correct. What I'm looking for is the formula to compute compression ratio given particular parameters...stock bore, stock stroke and compression. I'm not a math whizz so I don't know if that's possible, but logically, I would think it is. Alan
Old 10-16-2009, 11:56 AM   #6 (permalink)
bigbadal's Avatar
The cam is an ev27. Where are you going with this information?? I think I know, but I'm not totally sure. So maybe the durations of the valves being open and the overlap will change the compression ratio due to the air not being compressed till both valves are closed and the piston being "x" amount of distance from the bottom of its stroke?? Alan
Old 10-16-2009, 11:59 AM   #7 (permalink)
bigbadal's Avatar
Yes, but I seem to remember that your engine was bored twenty over, so it's not stock. So it would be slightly different than mine. I know I'm splitting hairs, but I'm just looking for a formula, if there is such a thing. Alan
Old 10-16-2009, 12:34 PM   #8 (permalink)
springer-'s Avatar
This can help figure it out, it may take a couple of educated guesses since you are "reverse engineering" it.... http://www.bigboyzheadporting.com/EVOComp.htm
207-621-8089
Old 10-16-2009, 01:16 PM   #9 (permalink)
mooooving out!
You need to know the intake close degree for the formula - it does go a little further, but this will give you a good guess. It also helps to know the baratric pressure when you took the comp test, but for best guess purposes, you elevation would be ok.
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
Old 10-16-2009, 02:13 PM   #10 (permalink)
bigbadal's Avatar
Thanks Springer. I'll explore that avenue.
Old 10-16-2009, 02:17 PM   #11 (permalink)
bigbadal's Avatar
Wow, I had no idea this was going to be such a complicated situation. Maybe, I'll try to find some chart that somebody else already figured out with all the right parameters and it will give me the ratio. Thanks, Alan
Old 10-16-2009, 02:55 PM   #12 (permalink)
springer-'s Avatar
If you use the link I supplied that is exactly what I have done. You pick your cam and that calculates the intake close and adjusts your cranking compression accordingly. Then enter in any known values like the bore, stroke, head gasket thickness etc. Then adjust your combustion chamber volume up and down until your cranking compression matches what you have. At that point it should give you a rough idea of the static compression ratio that you are looking for. I don't think you will find a better "chart" out there since there are way too many possible combinations. If you have any issue feel free to send me a PM and I will help with it.
207-621-8089
Old 10-16-2009, 03:45 PM   #13 (permalink)
Premium octane member
TXCHOP's Avatar
9.16 to 1 compression in a perfect world at sea level. Too many variables to be exact, but that's "close".
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 10-17-2009, 01:59 PM   #14 (permalink)
blackjackcustms is on a distinguished road
To measure an assembled motor, you'll need to orient it so the spark plug is it's highest point, set it at BDC and fill it with fluid from a graduated buret, note the volume, and then move it to tdc compression, and recheck the volume. Any number you get from the cranking compression and the cam closing will be a WILD guess.
The only way I would imagine this would matter is if you want to increase output, and if that's the case, then just take it apart and CC it, or change your cam until you get the performance you want from it. I have run on the street with as much as 230 psi cranking, and with a good ignition and careful tuning, it can be done. It will be Gasoline sensitive, and you'll have to watch what you fill it with, but it does work.
blackjackcustms is offline   Reply With Quote
