Depends on your transmission...
Some have an electric speedometer sensor on them,
Some have a cable drive, and
Some have nothing at all, the speedo on these bikes ran off a cable to the front wheel...
Sounds like the sensor or cable drive may be what you're looking for.
Since you've got an electronic speedo, you're going to need a sensor to "drive" it.
But, if its set up for a cable drive speedo off the transmission, you're going to have to get an adapter for the electronic speedo.
I think that Dakota Digital makes a set up for that. Might check some of the other parts vendors, Custom Chrome, Biker's Choice, etc...
Everyone wants to go to heaven,
Nobody wants to go now...
1987 FXRS-SP
.005" over 80-Inch, Andrews EV27 Cam
S&S "E" Carb - Ultima Single Fire Ignition
Manley Stainless Steel Valves & Crower Springs
Ultima Single-Fire Ignition
2-into-1 pipe (might be an LSR)
