No oil pressure
I have a 1991 Electra Glide Classic with an S&S oil pump. I've only had the bike for a couple months, and it's history is fairly vague (no service records) but it has run fine and given me no trouble. I rode it last night, and it seemed fine. So, today I start it from cold and there is no oil pressure. Zero. Nada. Gauge comes up slightly (apr. 2 psi) then goes down on start up. Light stays on. I never heard any noises, or anything unusual prior to the problem. . I checked for oil return to the tank. None. Oil level full. Pulled outlet hose on pump. Nothing. So, before I pull the pump off tomorrow, is there anything you guys could suggest I look for specifically? Like, can I tell if the shaft going into the cam chest is ok without pulling the nose cone? I'm familiar with twinkies, but this is the first Evo I've had, and obviously the oil pump is quite different. I have the FSM, but it's kinda vague concerning the pump. The oil pressure had been ok ( 10 psi at idle. 25 at 3000 rpm). I might just open up the cam chest anyway, so I can see what shape the cam bearing is in. It's just wierd, 'cuz there was no noise or wierdness prior to it going to carp. Anyhow, sorry for the long post. It's late, and I'm frustrated. Thanks
JD
Reason: too tired to think straight
