Motorcycle.com Classifieds!AdvanstarMotorcycleShowsPro PadCustom DynamicsProCharger.comMotorcycle-CommunicationBikeBanditRRcycles.comMotorcycle.comDan Vance RacingDiamond Bar Choppers
Pro Pad
Old 09-22-2009, 04:53 PM   #1 (permalink)
1990heritage's Avatar
1990heritage is on a distinguished road
How do I Lower RPM @ Highway speed HELP!
I do not have a tach but i think i must be turning close to 5000rpm at 70 mph. There is a bunch of vibration but the main concern is to reduce rpm. I have been thinking of changing the transmission and rear wheel pulley. I think the oem is 32 & 70. I have found 34 & 65
available. Has anyone done this? if so, is there a drive belt change needed as well? Is there a decrease in rpm that makes this transition worth while?
1990heritage is offline   Reply With Quote
Old 09-22-2009, 05:26 PM   #2 (permalink)
rob71458 is on a distinguished road
I would be willing to bet you are not any higher than 3500 rpm at 70mph. I could see changing one of the pulleys but not both. Your bike would become a dog, unless you have lots of torque on tap.
rob71458 is offline   Reply With Quote
Old 09-22-2009, 05:46 PM   #3 (permalink)
Y2K
Y2K is on a distinguished road
If you're turning 5K @ 70 mph your clutch is slipping.
Taller gearing or an aftermarket overdrive trans can get you there but having enough power to pull taller gears becomes an issue,even with a TC88" let alone an 80" Evo.
Y2K is offline   Reply With Quote
Old 09-23-2009, 03:58 PM   #4 (permalink)
aka_matt is on a distinguished road
stock gearing in those is about 24mph/1000rpm... or about 3000 @ 72... r u sure ur in 5th gear? if u make the gearing any taller, u'll be stalling it (or slipping the clutch real bad) at every take off and have no power to move that heavy bike...
Matt
FOR SALE
aka_matt is offline   Reply With Quote
Old 09-23-2009, 04:43 PM   #5 (permalink)
I do have power available
I bought this bike about 4 weeks ago. It has a S&S E Series Carb. with a K&N High flow and Harley turn out exaust and a EVL-3020 Comp Cam. This bike does have Balls.
Old 09-23-2009, 04:58 PM   #6 (permalink)
Z-Man747200's Avatar
Z-Man747200 is on a distinguished road
I did this on a rice burner a few years ago (rear sprocket only) and it worked fine but the point remains that if you are up to 5 grand at 70 mph, you have other fish to fry...my .02.
Z-Man747200 is offline   Reply With Quote
Old 09-23-2009, 08:21 PM   #7 (permalink)
You never said what size engine you have. Saying it has balls means nothing, it's your oppinion not a fact. You also say it revs to high, but have no way to back that up eather. Buy a tach and see where your revs really are first. It is a fact if you gear any bike "higher", it will decrease the torque output to the wheel which will affect the performance.
Old 09-23-2009, 10:54 PM   #8 (permalink)
ponderopa's Avatar
ponderopa is on a distinguished road
Maybe the vibration is your issue, making the rpm's seem high. Maybe a motor mount problem?
ponderopa is offline   Reply With Quote
Old 09-24-2009, 08:15 AM   #9 (permalink)
wdgld's Avatar
wdgld is on a distinguished road
5000rpm at 70?
No frikkin way, unless as previously mentioned, you have clutch slip issues.
wdgld is offline   Reply With Quote
Old 09-24-2009, 11:21 AM   #10 (permalink)
1997bagger's Avatar
1997bagger is on a distinguished road
If your rpm's at 70 is a fact, an 8 speed would be the only way to go to get your engine speed down to 3500 @ 70 mph
1997bagger is offline   Reply With Quote
Old 09-24-2009, 02:59 PM   #11 (permalink)
yeehaw is on a distinguished road
8 speed hahaha that's funny bagger. Before I rebuilt my 80" I had 34 on the trans shaft and 61 on the back, and a 5 speed trans. On deceleration the top of my belt rubbed on the jack shaft inner primary, due to the trans pulley being a bit taller. I didn't care it just was annoying, it sounded like a squeak. However, I used my bike on the highway most of the time. Off the line was a bit sluggish, but like I said I used it on the highway. Since then I am running, balanced flywheels, 9.5:1 comp., stock heads (re-worked), ev27 cam, S&S reed valve, 42 mikuni, and 2 into 1 thunder headers. Significant improvement in torque verses stock displacement. I now have a 6 speed trans., 32 on the trans pulley and 65 on the rear. I do not spend much time in 6th unless I'm up around 65 or so. I'm happy with the changes I made but, I'm set up for highway. Just my 3 cent nickel.
yeehaw is offline   Reply With Quote
Old 09-24-2009, 03:00 PM   #12 (permalink)
I forgot to mention my bike is a softail a little lighter than a bagger.
Old 09-24-2009, 06:21 PM   #13 (permalink)
qtrracer is on a distinguished road
If you bought it second hand are you certain that the pulleys are still the oem items? The trans pulley may have been changed to a smaller one thereby increasing rpm's and making it seem like it has more "balls".
08 SG 103" SE MVA Heads SE 10.5 Pistons SE 251 Cams SE 58 mm TB RB Racing 2-1
qtrracer is offline   Reply With Quote
Old 09-25-2009, 04:54 AM   #14 (permalink)
jtmurph00 is on a distinguished road
Go to Bakers website, they have an RPM calculator on there, pretty handy, just put in what you've got. I had to go to a 70 tooth rear to run a narrow belt so I put a 34 tooth in front. According to them it comes out to within 100 RPMs the same.
jtmurph00 is offline   Reply With Quote
Old 09-28-2009, 04:28 AM   #15 (permalink)
tonight
Good Point!! I will be getting the bike on the lift tonight and i will start counting.
