Oil - and lots of it!
My custom EVO is leaking major oil from the left side engine seal. This is a brand-new build and the second seal I've installed. The motor is 103." I've been told to install it backwards for open belt applications..? Seems if it sits longer than a week without starting I get a puddle on the garage floor once it starts. Also, it seems to be "breathing" way too much oil from the crankcase breather valve - which I was told was "normal." Oil pressure (if I remember correctly) was about 25-30psi at idle.
Here are the specs:
...running open belt....103" EVO engine (originally assembled back in 98' so all parts are from that year)...Sputhe cases, S&S flywheels, rods and pistons, Manley Valves, Andrews EV72 Cam, S&S oil pump, S&S Super G carburetor (is this too big for 103"?), STD heads (not setup with breathers), Jim's Roller rockers and Cam cover, solid lifters....HELP!
