Yep, you should be able to find the CV carb and manifold at most larger swap meets. Cables, I'd buy new ones. Just be sure, if you buy a swap meet carb, that's it's still in basically stock mode, that is, the slide hasn't been drilled and/or messed with. You could also ask on here. A TC CV carb will also work fine if the jets/needle are changed.
Ed Y
2002 FLTRI
I yam what I yam.
