High oil Pressure followed by smoke out of front cylinder
I have a S&S 124" evo with b2 heads which i installed this spring to make it a 126. I have all the power i need and this problem hasnt effected the performance but is an issue i cant seem to solve. I run about 25-30 psi at idle and 40-45 at cruising speed and once the smoking occurs it drops to where it should be 12-15psi at idle and 30-40 at cruising. the problem consists of my front cylinder blowing almost a white colored smoke once in awhile at all different temps, speeds, and rpm. it most often happens when i get off the highway and stop at a light then go to take off it smokes out the intersection. I have done a compression test, leak down, installed a new hvhp oil pump, new ignition, blown out all the oil lines, checked for intake leak, pulled apart the top end and checked everything including rings, valves, valve guides, and seals.
I have been fighting with this problem all year and am in need of a new direction. PLEASE HELP
