JekillandHyde.eu
Dan Vance RacingMotorcycle-CommunicationMotorcycle.comMBO EnterprisesRRcycles.comAmerican Side Road CycleFuel MotoCycleGear.comCustom Dynamics
MBO Enterprises
Old 08-22-2009, 11:48 PM   #1 (permalink)
90Harley is on a distinguished road
Collapsed lifter?
Is a collapsed lifter pretty much bottomed out on the spring and not releasing back up? I have a pushrod that all of a sudden has about 1/4" - 1/2" play. Is that what I am looking at? I am in the process of m oving and havent had time to take it apart.
Front intake lifter on a 1900 mile fresh build.
90Harley is offline   Reply With Quote
Old 08-23-2009, 12:03 AM   #2 (permalink)
BIGBOPPA is on a distinguished road
I dont know if this is your problem, but I put new adjustables in when I did my top end rebuild a few months back, and about 500k's later, one of the lock nuts came loose, after constantly hitting the inside of the tube, and the adjustment backed itself off, to the point where the pushrod was not even opening the valve. I modified the pushrod tubes, and retightened everything and now 2000k's later everything is still fine.
BIGBOPPA
MICAH 6:6-8
PLEASE,DO NOT MAKE ME HAVE TO USE MY UNDERTAKERS VOICE!!!
1986 FXRS
80" EVO
Andrews EV27 Cam
Supertrapp 2:1
Mikuni HSR42 Carb.
Ultima Fully Programmable Single Fire Ignition
Wide Glide Conversion
Fork Brace
Progressive Front Springs
Sports Front Fender
Koni Rear Shocks
Homemade Custom Seat
BIGBOPPA is offline   Reply With Quote
Old 08-23-2009, 12:12 AM   #3 (permalink)
Yep, I pulled the pushrod cover hoping for that. Instead it looks like the pushrod is good and cannot seem to see the top of the lifter. Lots of play. That is all I did and may have a few minutes tomorrrow to look farther. Guessing the lifter is currently down, but there is nothing there at all to hold the rod up.
Just a guess the inside collapsed. happened at 70 cruising and then missing then really missing before I shut it down. It would start after that but not right and the oil pressure was gone.
Old 08-23-2009, 12:37 AM   #4 (permalink)
Yes well unfortunately it sounds like either a collapsed hydraulic lifter or a collapsed cam follower wheel. This would be more consistent with a loss of oil pressure, I hate to say, because if that has happened, it is usual for one of those roller bearings to go into you oil pump and shear the key way on your oil pump shaft. Not trying to be a prophet of doom here, but if that is the case (and I hope it isnt, for your sake) it will cot a bit to fix, because it probably will have stuffed a lobe on you cam as well which will need replacing, and probably the lifter block as well, not to mention a new oil pump, depending on the amount of damage inside the pump.
BIGBOPPA
MICAH 6:6-8
1986 FXRS
80" EVO
Andrews EV27 Cam
Supertrapp 2:1
Mikuni HSR42 Carb.
Fork Brace
Sports Front Fender
Koni Rear Shocks
Old 08-23-2009, 11:21 AM   #5 (permalink)
tony g's Avatar
tony g is on a distinguished road
same thing happened to me, the bearing collapsed on a follower and trashed my cam !!!!!!!!!! had to replace all the followers and i fitted an EV 27 cam.
tony g is offline   Reply With Quote
