K know that I'm late in chiming in, but just in case you're still having the issue, the midrange circuit is your needle jet, the one that goes right thru the middle of the carb slide. The DynoJet kit comes with an adjustable needle, where you can move a little "c" clip into different notches machined into the top of the needle.
After removing the needle, hold it with the pointy side down & the clip side up. What you'll want to do in order to richen up the mid circuit is to carefully move the clip down one or two notches towards the pointed end of the needle. This'll raise the needle up in its seat & allow more fuel to flow past.
Give it a try, & be careful with the slide diaphragm. An easy way to reassemble it without pinching the diaphragm is to put the slide/diaphragm in a ziplock bag, then put it in the freezer for a couple of hours. This'll cause the diaphragm to temporarily shrink a bit. Don't pull it out until you're ready to reassemble the carb. It should seat nice & easy.
Hope this helps somewhat. CV carbs really aren't that difficult, when you get the different circuits sorted out. Pretty easy to tune.
Danny
Black Betty
1988 FXRP
