I have a 91' evo with a 99' motor and I went with Ultima electronic ign. A.K.A. Dyna and used my stock coil. I'm sure someone here would know. My guess is, it is the same as mine. I set mine up as dual fire single plug. Ultima gives different options. Dual, single fire, and where to set your curve depending on engine combination. Piston, bore, stroke, cam selection etc. The updated electronic pick-up is soo easy to install, and it made static timing a snap with the L.E.D. light.
