ProCharger.comRRcycles.comMotorcycle.com
Pro PadAdvanstarMotorcycleShowsMotorcycle-CommunicationLeslie Kay'sJardineProducts.comCycleGear.comMBO Enterprises
Old 08-08-2009, 04:27 PM   #1 (permalink)
wanna ride's Avatar
wanna ride is on a distinguished road
motor build
I'm looking to do a total rebuild on my new to me 89 FLHTP as soon as the weather starts turning cold which won't be all that long up here. The bike has 138,000 km on the motor. I did a compression test on stone cold motor and got 115 psi. The bike actually runs quite well other than a bit of oil leaking from cam cover area. So I guess I should get to the question, seeing as I'm planning to redo the entire motor starting with the valves guides and working down to bottom end what can I purchase to start filling the shelves in preparedness of the build without opening up the motor other than the obvious motor gasket kit? I have no idea what size pistons are in the bike seeing as I just got it 700 miles ago. I'm not looking to build a ratical motor just a hi milage good 2 up riding bike.
2002 FXDWG
1989 FLHTP
Lynn
wanna ride is offline   Reply With Quote
Old 08-08-2009, 08:28 PM   #2 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
Can't beat the price of the Factory rebuild program for the Evos.
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
Old 08-09-2009, 01:42 AM   #3 (permalink)
wanna ride's Avatar
Yes I have thought of this direction as well, in fact I've been trying to get together a list of prices for parts and shop machining prices to compare with.
2002 FXDWG
1989 FLHTP
Lynn
Old 08-09-2009, 07:15 AM   #4 (permalink)
econnor is on a distinguished road
You will need new lifters for sure, might want to think about a cam upgrade, new hardware maybe, rocker arm shafts and bushings.
econnor is offline   Reply With Quote
Old 08-09-2009, 09:53 AM   #5 (permalink)
Last one I had rebuilt using the factory program was a bit over $2k. There's no way I could rebuild it bottom to top....and use new components like they did....for that price. The only thing that we noticed used and re-built when we got it back was the flywheels and the .010" os cylinders. Everything else was new....heads, cases, lifter blocks, etc... even the bored cylinders had fresh machining on the fins and new powdercoat.
Old 08-09-2009, 10:46 AM   #6 (permalink)
Beemervet's Avatar
Beemervet is on a distinguished road
So if it ain't broke, why are you fixing it?
Beemervet is offline   Reply With Quote
Old 08-09-2009, 12:41 PM   #7 (permalink)
gsxrboy96's Avatar
agreed, that motor is barley broke in, do a top end kit, send your heads off to hillside for a freshing as well as the cylinders, put a lil camshaft such as ev27 or evl3020, and it will feel like a whole new bike.
Old 08-09-2009, 01:25 PM   #8 (permalink)
wanna ride's Avatar
I just figured with the amount of milage it may be a bit tired.
When I did the compression test it was cold and I neglected to open the throttle and got 115 psi even on both jugs, today I will check them while hot and throttle open.
2002 FXDWG
1989 FLHTP
Lynn
Old 08-09-2009, 01:25 PM   #9 (permalink)
wanna ride's Avatar
Already on the list.
2002 FXDWG
1989 FLHTP
Lynn
Old 08-09-2009, 01:27 PM   #10 (permalink)
wanna ride's Avatar
I've heard that the bottom ends are good for three top end jobs although I would think a fresh top end would be hard on a tired bottom end.
2002 FXDWG
1989 FLHTP
Lynn
Old 08-09-2009, 09:59 PM   #11 (permalink)
wanna ride's Avatar
Got around to doing the compression test with motor hot and throttle wide open which I beleive is the correct way of doing it, I got 140 psi on both which is better than originally thought. So I got a question, if compression is descent ( at least I think it is ), does good compression and a none smoking exhaust indicate that the heads and cylinders are good and no motor job is needed?
The bike seems to run ok although it doesn't compare in torque to my 02 Dyna WG when were 2 up riding. And if motor doesn't need anything what can I do to improve torque on than the suggested cam. Aren't these copbikes suppose to have a better than stock cam already?
2002 FXDWG
1989 FLHTP
Lynn
Old 08-09-2009, 11:22 PM   #12 (permalink)
gsxrboy96's Avatar
with just a ev27, the bike will feel like a whole new bike......the way harley should have rolled them outta the factory, and if you have a rep shop such as hillside do a valve job with a lil clean up port work and deck the heads, that old evo will destroy your dyna. i wouldnt worry too much about the bottom end, you can usually mileage the snot outta those, and if your real concerned with it, id take the jugs oversize and put a lil compression in the bike, just my two cents.
Old 08-11-2009, 12:21 AM   #13 (permalink)
wanna ride's Avatar
Ok so I decided I'm going to start with
HQ-0024 CAM, Rumble Stick Evo
HQ-2500 JETS, CV carb tuner kit
HQ-6000 IGNITION, Evo programmable
This winter I will send the jugs and heads to Doug at HQ. This should make a differnce.
2002 FXDWG
1989 FLHTP
Lynn
Old 08-12-2009, 02:20 AM   #14 (permalink)
wanna ride's Avatar
gsxrboy96 do you have a decker that you put the cam into? I'm wandering if there is going to be a small differnce or a large noticeable differnce with the cam and ignition. I can bet there is goign to be more noticeable differnce once the heads and jugs are done.
2002 FXDWG
1989 FLHTP
Lynn
Old 08-12-2009, 08:50 AM   #15 (permalink)
gsxrboy96's Avatar
Lynn, im not sure what you mean by decker? But when i first bought my dresser, it was stock, so i just threw a ev27 at it, and it was a big difference, Then i bought a set of cycle rama heads and jugs that were .020 over with wiseco 10.1 pistons, The bike ran better than before, but not what i expected, but after going to a woods w6, the bike ran it ass off, but the noise was a little more than i cared for, so i put a vthunder camshaft in the bike, and am happy, I will tell you this, my bagger will outrun stock 88 inch dynas all day,,,and a buddy of mine has a 95 inch kit in a night train, and we are dead even, so you will be quite happy if you do all those modifications, as far as ignition, besides elimininating the stock 5200 rev limiter, you will see no difference in power with ignition.
