Motorcycle.comPro PadProCharger.comBub EnterprisesMBO EnterprisesDiamond Bar ChoppersMotorcycle-CommunicationSportbikeTrackGearLeslie Kay's
SportbikeTrackGear
Old 08-07-2009, 09:23 PM   #1 (permalink)
jcorso11 is on a distinguished road
1998 Softail starter install
Removal went pretty much according to plan, reinstall....
There is a sleeve that covers that starter shaft and the shaft that goes into the primary, basically a slightly larger sleeve... the sleeve is tapered on one end.
2 questions. 1 is if the taper goes towards the starter or the primary...
2. The shaft has a snap ring inside it.... it would appear that said snap ring should be on something... not just in the sleeve!!!! any assistance would be AWESOME!!!!
Joe
jcorso11 is offline   Reply With Quote
Old 08-07-2009, 09:28 PM   #2 (permalink)
--Doof 43--
Serg06's Avatar
Serg06 is on a distinguished road
the snap ring stop the shaft from going further down the starter shaft. You should be able to tell by how far down the shaft the sleeve goes. It is supposed to cover the starter shaft and the snap ring will bottom out when installed properly. I can't remember but I think the short side goes towards the starter.
Serg
06 Street Glide (Sheala) 124" S&S
Super sucker A/C
True Duals.
THE SCORE:
Asphalt=1
Me=0
Serg06 is offline   Reply With Quote
Old 08-07-2009, 09:35 PM   #3 (permalink)
rcsoftail is on a distinguished road
I can't remember either, but the start shaft will be almost completely covered by the sleeve.
rcsoftail is offline   Reply With Quote
Old 08-07-2009, 09:40 PM   #4 (permalink)
--Doof 43--
Serg06's Avatar
And the snap ring will be on the starter shaft.
Serg
Super sucker A/C
True Duals.
THE SCORE:
Asphalt=1
Me=0
Old 08-07-2009, 09:50 PM   #5 (permalink)
ok.
So i put the snap ring on the groove of the starter? Then which picture is right?
image 99( which the taper towards starter)
image 98 (taper towards primary)
Old 08-07-2009, 09:52 PM   #6 (permalink)
--Doof 43--
Serg06's Avatar
Tapper towards primary. it has to go through a seal.
Serg
Super sucker A/C
True Duals.
THE SCORE:
Asphalt=1
Me=0
Old 08-07-2009, 09:55 PM   #7 (permalink)
so, the coupler will cover the starter shaft completely?
Should the snap ring be attached to the shaft of the starter? or just resting against it?
Old 08-07-2009, 09:57 PM   #8 (permalink)
--Doof 43--
Serg06's Avatar
Just resting against it. Put the tapper towards the primary and slap that bitc& on.
Serg
Super sucker A/C
True Duals.
THE SCORE:
Asphalt=1
Me=0
Old 08-07-2009, 11:35 PM   #9 (permalink)
OK.... call me crazy... but this can only go on one way, right???
I tried it the way you explained, and ill be.... Nothing.
I think we were looking at different tapers... Either way, i swapped it, and bam... all set.
Going the way you said, I couldnt do ANYTHING to get the shaft screw to reach the starter....
I spun it over, and its engaging perfectly...
SO, the million dollar question... Can this piece be swapped, or is it a one way installable part. (the coupler)
Old 08-08-2009, 10:04 AM   #10 (permalink)
anyone. I just about have this buttoned up, and before I put oil in, i want to confirm that its right.
Joe
Old 08-08-2009, 12:51 PM   #11 (permalink)
Your first picture 898 looks correct to me. The longer section goes over the starter shaft. The snap ring stays in the sleeve and butts up against the end of the starter shaft. I did one a few months ago and my memory is starting to come back.
