It is really quite simple,except for clearance issues with tanks and other jewelry.An allen wrench is all that you should need to remove the covers.Just make sure that when you start on the resealing that you tighten the cover screws equally and in small increments,don't tighten one side down tight while the opposite side is real loose.These gaskets have a way of moving around.
