Motorcycle-CommunicationCustom DynamicsSportbikeTrackGearAdvanstarMotorcycleShowsDiamond Bar Choppers
RRcycles.comFuel MotoBub EnterprisesProCharger.com
Old 07-31-2009, 02:01 PM   #1 (permalink)
kools20 is on a distinguished road
:confused: lifter question
Ok guys i got one for ya 93 softail S&S 651 cam heads & carb just put in new cam S&S 651 as far as the lifters go i bought a new set of street preformer lifters and now have a miss fire when i gas on it so was wondering if i can take the guts out of the stock lifters and install them in the body of the street preform. ones since i believe there might be something wrong possibly with the springs in the new ones or it could be that they said they were good for cams up to a 650 lift this was just a thought i had
kools20 is offline   Reply With Quote
Old 07-31-2009, 04:14 PM   #2 (permalink)
I don`t think the springs in your lifters are your problem, but those street performer lifters go for less than 60 bucks a set, el cheapo lifters are not a good way to save money...
Old 07-31-2009, 04:22 PM   #3 (permalink)
hbmc's Avatar
Besides if the old guts fit into the new case why not use the old lifters as they should fit in the hole? Maybe you got a springload issue? Let it bleed down then snug with fingers 3 turns or whatever it calls for.... I know the old lifters are worn and it wont be a good marriage with new and used parts touching. How worn are the old ones? will scotch brite clean them up? Because now the cam is used too technically---right?
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
