My 94 Fat boy is cutting out under full throttle once I hit 2nd gear and above. It almost sounds like it's starving for something. It doesn't cut out for a long time, just split seconds, then ok, then cuts ok, then ok.
It has a crane HI-4 ignition, not sure what else has been done to it. The front cylinder spark advance dial is turned all the way to the right. Plugs are gapped at around .042. It has an aftermarket cam, not sure which one. S&S Shorty carb. Straight pipes.
The other thing I noticed was pretty bad mileage. My first complete fill up sine I bought it yielded 33 mpg.
