American Side Road CycleSportbikeTrackGearCycleGear.comMotorcycle.com Classifieds!Custom DynamicsFuel Moto
ProCharger.comAdvanstarMotorcycleShowsDiamond Bar ChoppersJekillandHyde.euBub EnterprisesLeslie Kay's
Old 07-31-2009, 01:22 AM   #1 (permalink)
LordofEntropy is on a distinguished road
Oil Change - Only 1 Quart comes out
The level is still at full while on kickstand and hot. Drained the bike, or so I thought, changed the filter and only 1 quart goes in before it is too full even. Try to drain it out and almost none will drain, maybe another half a quart.
What might the primary culprit be? The manuals say about 4 quarts. I know that can vary due to expansion and what not. One quart is certainly too little.
Any ideas or suggestions would be appreciated!
LordofEntropy is offline   Reply With Quote
Old 07-31-2009, 04:15 AM   #2 (permalink)
BIGBOPPA is on a distinguished road
Hi Lordofentropy,
You didnt say what kind of bike it is . One thing to remember is that the oil level should be checked with the bike upright, not on the side stand. Depending on what side of your bike the oil tank is on, your oil level will either be way too high or way too low if you check it on the side stand. I dont know if this is the problem, but it is just something to think about.Hope you sort it out.
BIGBOPPA
MICAH 6:6-8
PLEASE,DO NOT MAKE ME HAVE TO USE MY UNDERTAKERS VOICE!!!
1986 FXRS
80" EVO
Andrews EV27 Cam
Supertrapp 2:1
Mikuni HSR42 Carb.
Ultima Fully Programmable Single Fire Ignition
Wide Glide Conversion
Fork Brace
Progressive Front Springs
Sports Front Fender
Koni Rear Shocks
Homemade Custom Seat
BIGBOPPA is offline   Reply With Quote
Old 07-31-2009, 07:26 AM   #3 (permalink)
baggersport's Avatar
baggersport is on a distinguished road
...are you sure you're draining the engine oil? Two drain plugs in the pan, one is for the transmission.
www.bigboyzheadporting.com
Big Boyz Street Heads
207-242-8374 Cell Phone
207-621-8089 Port/Dyno Shop
baggersport is offline   Reply With Quote
Old 07-31-2009, 07:48 AM   #4 (permalink)
not to be taken seriously
tomv's Avatar
tomv is on a distinguished road
gonna be an oops here somewhere....
mile high asskickin club...try that in my town pal...
its all fun and games till someone gets hurt...then its one of americas funniest hime videos...
tomv is offline   Reply With Quote
Old 07-31-2009, 08:19 AM   #5 (permalink)
strokerjlk's Avatar
your profile says 95 ultra
I suspect bean is correct.
trans fluid needed changed anyway LOL
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 07-31-2009, 09:05 AM   #6 (permalink)
Doof Bag
huckinfog's Avatar
huckinfog is on a distinguished road
my thoughts as well, didn't drain the engine oil tank.
Believe in all the good things,that money just can't buy
Then you won't get no bellyache, from eatin' humble pie
I believe in rags to riches, your inheritance won't last
So take your Gray Poupon my friend, and shove it up your as*.-Aerosmith
huckinfog is offline   Reply With Quote
Old 07-31-2009, 09:18 AM   #7 (permalink)
pirate50's Avatar
pirate50 is on a distinguished road
Some bikes DO specify that the oil level be checked while the bike is resting on the jiffystand. It screws people up when you throw out "facts" that aren't factual.
Pirate
pirate50 is offline   Reply With Quote
Old 07-31-2009, 10:31 AM   #8 (permalink)
Faast Ed is an unknown quantity at this point
Pirate
Changed a few times on Heritages (can't speak for the other models). Some years "jiffystand" some years not. My 08 is on the Jiffystand. Trans too.
Faast Ed is offline   Reply With Quote
Old 07-31-2009, 10:36 AM   #9 (permalink)
tomv's Avatar
i'm pretty certain the jiffy stand crap doesnt make a 3 quart difference here guys...we get it...
Old 07-31-2009, 10:42 AM   #10 (permalink)
LOL Tomv, I meant to add in my last post that I had agreed with the "trans fluid mistake" post.
Old 07-31-2009, 10:48 AM   #11 (permalink)
pirate50's Avatar
Yeah, that's why I only addressed the "checking" part and not the wrong drain plug part.
And I hope that other people get the facts right too.........
Pirate
Old 08-01-2009, 04:12 AM   #12 (permalink)
Yes, a 95 Ultra Classic Electra Glide, I put it in my profile and forgot to mention it in my post. This particular bike does need to be checked on its stand. I am as certain as I can be that it is indeed the oil plug unless the manuals are labeled wrong.
Old 08-01-2009, 05:03 AM   #13 (permalink)
Pirate
OK, I stand corrected, sorry for any confusion I may have caused, its just that every Harley I have ever owned has specified that it must be upright to correctly check oil level.
BIGBOPPA
MICAH 6:6-8
1986 FXRS
80" EVO
Andrews EV27 Cam
Supertrapp 2:1
Mikuni HSR42 Carb.
Fork Brace
Sports Front Fender
Koni Rear Shocks
Old 08-03-2009, 01:38 PM   #14 (permalink)
strokerjlk's Avatar
well what did ya find?
wrong plug?
or checking on the kick stand made a 3 qt diff? LOL
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 08-03-2009, 01:52 PM   #15 (permalink)
55Bubba is on a distinguished road
On my 95 Ultra, the engine oil drain is the most forward of the two drain plugs and actually faces toward the front of the engine. It's slightly to the left side of the engine. The tranny drain plug is straight up and down more toward the right side and rear of the bike. It's easy to think the tranny drain is the oil drain. I almost made that mistake myself the first time I changed the oil.
Hope this helps
Bubba
55Bubba is offline   Reply With Quote
