Motorcycle-CommunicationProCharger.comCycleGear.comDan Vance RacingMBO EnterprisesLeslie Kay'sJardineProducts.com
Old 07-27-2009, 09:49 PM   #1 (permalink)
shine50 is on a distinguished road
New member with couple of questions?
I have a 94 Road King. Just put new battery on this weekend and it made it about 10 miles. The bike failed to start. After pushing it we pulled the positive post off while running and it died. The bike was just completely rebuilt in december. There was a new stator installed at that time so I'm needing to know what to look for now. Also the bike is missing gears at times, gets stuck in between gears. Need help, Thanks. Shine50.
shine50 is offline   Reply With Quote
Old 07-27-2009, 10:10 PM   #2 (permalink)
econnor is on a distinguished road
Shine, unplug the regulator from the stator. With the engine running at a very high idle, you should have around 100 plus VAC coming out of the stator. If not, then the stator is bad. If voltage at the stator is good, the next check is at the battery. With the engine at a high idle, there should be around 14.4 VDC at the battery. If not then thevoltage regulator is bad. Before doing these checks, check every connection for tightness and loose cable ends. Make sure the battery is fully charged also. Once you have 14.4 VDC at the battery your next check should be for current draw.With the ignition key turn completely off, remove one of the battery cables and measure current draw. There should not be any current being drawn, if there is current draw, then something is shorted in the electrical system. To isolate the draw, start by unhooking electrical connections until the current draw stops.
econnor is offline   Reply With Quote
Old 07-27-2009, 10:19 PM   #3 (permalink)
Thanks for the quick response. I'll check it out.
Old 07-28-2009, 08:58 AM   #4 (permalink)
Iron Will
Hillside's Avatar
If it is now missing the gear change AFTER, the re-build, I would suspect a clutch adjustment.
Scott
