Motorcycle-CommunicationDiamond Bar ChoppersMotorcycle.com Classifieds!Bub EnterprisesProCharger.comPro PadSportbikeTrackGearAmerican Side Road CycleMBO Enterprises
Old 07-22-2009, 05:52 PM   #1 (permalink)
bigbadal's Avatar
bigbadal is on a distinguished road
Question CV carb jetting with mods
I have 94 evo ultra. CV carb, ev 27 cam, evo heads with stock valves, ported/polished combustiion chamber and 100 thou off the heads, ultima ignition, single fire system. I just redid these heads and had to put the new ignition module in cause I broke the other one putting it back in. The bike seems to run good, I can feel the difference, but it is running hotter (temperature wise). Plugs show pretty white. When I put heads on that jumps my compression from 8.5 to 9.6 (according to an Andrews table), should I have to change the jetting for the cv?? And with more compression, does the timing stay at 35 degrees BTDC?? The bike seems to miss verry slightly at cruising speeds (60 to 80). Almost imperceptably, but I can feel something that isn't quite right. Any thoughts?? Alan
bigbadal is offline   Reply With Quote
Old 07-22-2009, 07:44 PM   #2 (permalink)
Iron Will
Hillside's Avatar
I'd pull 3-4 degrees of timing out, and set the carb with a 45 pilot and 175 main, air idle screw at 3 turns out.
This is only BASELINE timing/jetting. It should help.
Scott
Old 07-22-2009, 10:16 PM   #3 (permalink)
bigbadal's Avatar
Scott
Thanks for the comeback. I do have a 45/180 setup in the cv right now, but I'm using the almost straight fat sportster needle in the slide. It ran fine before the headwork and new ignition. The only reason I had to change ignition modules is because I broke the magnetic pickup on the back side of the mounting plate. I couldn't find the same brand, so I settled for an Ultima 644. Only thing is, I have a hard time with the directions on setting the timing with a light. I can static time it but I would like to check it with a light. To me, the instructions leave something to be desired. And I can't talk to a tech from Ultima cause they don't deal with retail. The dealer I bought it from says he don't time with a light, only static timing. The instructions say that I have to ground the wire that goes to the voes! Sheez, I have to take my tank off and ground the wire and then put the tank back on, try to time it and then take the tank off and reconnect the voes and then put the tank back on. What a deal. There's got to be a better way. The advance curves are built in to the module, but I want to see for myself with a light in the window that I am reaching my optimum advance. You have any other thoughts on this timing thing?? BTW, I checked for intake leaks couple of hours ago. No leaks that I could detect. If my timing is retarded, will that make the bike run hot and lean?? Thanks, Alan
