Pro PadMBO EnterprisesCycleGear.comDan Vance RacingDiamond Bar ChoppersMotorcycle-CommunicationFuel MotoLeslie Kay'sCustom Dynamics
Old 07-19-2009, 11:14 PM   #1 (permalink)
sumerfun01 is on a distinguished road
Smile 98 evo reliability
reciently purchased a 98 police road king that was obviouslly hammered on. Been reading about all the evo cam rearing nigthmeres. My motor has 36000 on it and seems to run good but you guys are making me nervous. How long should I expect this mill to last with reasonable use? Is my motor a time bomb? Thanks for any feedback.
sumerfun01 is offline   Reply With Quote
Old 07-20-2009, 12:21 AM   #2 (permalink)
mooooving out!
route66paul's Avatar
You have an Evo, there is nothing to worry about.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
route66paul is online now   Reply With Quote
Old 07-20-2009, 12:25 AM   #3 (permalink)
dickey is on a distinguished road
The cam bearing problems are on the Twin Cams,which didn't come out 'till '99. IMHO, Even though I own 2 Twin Cams, I think the Evo is the best & most reliable motor Harley ever made. Enjoy your sled & don't worry.
dickey is offline   Reply With Quote
Old 07-20-2009, 01:35 AM   #4 (permalink)
TheNowhereman's Avatar
I ran my 80 inch EVO for 100k.
It was pumped up fierce putting out 104 hp.
It still is strong but sitting in my garage.
Those motors if oil changed every 3k are bullet proof.
Nowhereman who else?
Old 07-20-2009, 08:37 AM   #5 (permalink)
Smuggler
I have over 100k on my 1998 Evo. Outstanding motor.
Old 07-20-2009, 10:07 AM   #6 (permalink)
rewind's Avatar
rewind
EVO's are great engines!!!! I've got almost 50k on mine. If it hasn't been done I'd put in an Andrews EV27 cam and also replace that INA cam bearing with a Torrington.
Ride what you like, like what you ride
1997 FLSTC
"Hanging in, Hanging on, Hanging out"
rewind is offline   Reply With Quote
Old 07-20-2009, 12:44 PM   #7 (permalink)
4XLT's Avatar
4XLT is on a distinguished road
what everyone said...
i have a 98 E-Glise and when i bought it 3 years ago it had 52K on it. i put another 18K hard miles on it and then stroked it to a 93"
i know a guy that has 213K on his 87 Heritage with only a re ring job done after 175K. he does not beat it but still rides allot.
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
4XLT is offline   Reply With Quote
Old 07-27-2009, 06:01 PM   #8 (permalink)
mtkawboy is on a distinguished road
If you still have the stock factory cam bearing Id get it out of there ASAP if it isnt already too late. I dont know about all these trouble free ones but Ive seen dozens with spun cam bearings. They have a plastic cage on them & spin in the cases. I had an Andrews EV13 cam & the $10 bearing out in mine at 2000 miles. From what Ive seen its the best $10 youll ever spend. I later changed it my self to mackie heads & a Comp Cams 3030, 240 duration, 530 lift.
mtkawboy is offline   Reply With Quote
Old 07-27-2009, 08:48 PM   #9 (permalink)
NHFree1's Avatar
NHFree1 is on a distinguished road
I agree. I don't know why everyone is saying not to worry. If you've seen what the INA bearing looks like, you would get it out of there too and replace it with the full roller Torrington. My bearing was ok after 17k miles but the guy I sold my bearing remover to had a spun bearing with 23k miles. Bearing hadn't disintegrated completely, but after flushing the bits of the bearing from his cases, he's still changing his oil and cutting open oil filters every 300 miles for at least 1200 miles to check for pieces.
It's not worth the risk and you will be kicking yourself if the $10 bearing lets go and you're saddled with $4000 in repairs. Just change the bearing. With the gaskets and adjustable push rods, you'll still be under $150 for everything. You can buy the bearing puller on ebay for $80 and then sell it after so you'll get that back. Just do it though. If you don't want to listen to us, then search INA cam bearing and read the hundreds of threads on it.
"To sit back hoping that someday, some way, someone will make things right is to go on feeding the crocodile, hoping he will eat you last - but eat you he will." – Ronald Reagan
NHFree1 is offline   Reply With Quote
Old 07-29-2009, 01:39 PM   #10 (permalink)
rcsoftail is on a distinguished road
I am a victim of the INA cam bearing failure in my 1995 softail. Change it to the torrington before it is too late. I was thinking Harley went back to the torrington bearing in the later years, but not sure which year.
rcsoftail is offline   Reply With Quote
Old 07-29-2009, 07:58 PM   #11 (permalink)
NHFree1's Avatar
I believe they used the INA from 1992 to 1998 and switched back to the torrington in 1999.
Old 08-01-2009, 07:19 PM   #12 (permalink)
chetg is on a distinguished road
i have a 95 flt ,with 56000 miles on it. not one oil leak still running strong.
chetg is offline   Reply With Quote
Old 08-01-2009, 10:27 PM   #13 (permalink)
Unca Mike is on a distinguished road
If the bike was used by a local police dept you could go to their service dept head and find out the history of the bike. It might have had the cam bearing changed already.
Unca Mike is offline   Reply With Quote
Old 08-02-2009, 01:35 AM   #14 (permalink)
Beemervet's Avatar
Beemervet is on a distinguished road
See above posts. Ina bearing is a known issue for EVOs.
HEY!! Who let this Twinkie guy in here?
Beemervet is offline   Reply With Quote
Old 08-02-2009, 10:44 PM   #15 (permalink)
your motor is a lot more reliable than the twin cam crap. should last you 100k at least good luck ride safe.
