Leslie Kay's
Old 03-19-2009, 09:00 AM   #1 (permalink)
rsnky is on a distinguished road
No Power
HELLO,I have been to some really neat sites about my problem,an I have found alot of good info,but I need more,the problem i was stripping bike down to have it painted two months ago,well the bike is back,hooking everything back all connections are made,an i have no power at all,I have the battery,I have 13.50 volts, I have power to the starter,but thats about it,what am I missing,it was working when i disassembled it,,any help would be great. This is on a 1990 Harley,electrica glide ultra
rsnky is offline   Reply With Quote
Old 03-19-2009, 10:29 AM   #2 (permalink)
4XLT's Avatar
4XLT is on a distinguished road
basically your going to have top retrace every connection, make sure every wire is hooked up to the proper connection and also checking for grounded wires... it's a pain in the ass but it has to be done
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
4XLT is offline   Reply With Quote
Old 03-19-2009, 11:54 AM   #3 (permalink)
DILLIGAF
RattFXR is on a distinguished road
Good luck, that's a painful process. Make sure your grounding strap under the bike is hooked up, the ground from the battery to the primary is also. If you forgot the frame to primary (under bike) it might cause a problem or too.... I have a 90 FXR so our grounding points should be the same. And the primary to frame (underbike) can definitely be missed....
RattFXR is offline   Reply With Quote
Old 03-19-2009, 12:36 PM   #4 (permalink)
i did use a lift when i torn tthe bike down,maybe by some chance the grounding strap go ripped,i will check that,thanks for your all help.
