Andrews EV-23 Cam ? : V-Twin Forum: Harley Davidson Forums
Old 12-01-2008, 08:10 PM   #1 (permalink)
JohndeereB wants to know Dino or Syn?
Andrews EV-23 Cam ?
I just ordered a EV-23 cam for my 93 FXR with 8,500 miles.
Does anyone have an opinion on the EV23 vs EV13 or EV27?
I have bags, windshield and ride under 70 mph, will the mileage
be better or worse than a stock cam?
Does the Andrews have a keway under the cam gear like a
Crane, so you can use the stepped pin with the two pins clamped
around the gear to align your orignal cam gear properly when
pressing it on the new cam? should the gear be heated before
JohndeereB is offline   Reply With Quote Quick reply to this message
Old 12-02-2008, 09:16 AM   #2 (permalink)
head's Avatar
head wants to know Dino or Syn?
ive got a group of buddies that all have ev23 cams in their evos,including me. better fuel economy. nice chop or lope to it. improved power. good bottom and mid and keeps up pulling. the 27 is a little hotter but ive been real satisfied with the ev23 for over 100,000 miles. if i had to put in another cam, it would be the same.
head
head is offline   Reply With Quote Quick reply to this message
Old 12-03-2008, 11:55 AM   #3 (permalink)
Thanks Head
I got the cam and it does have a .250 wide keyway 180 degrees from the pinion tooth
"dot" so it should be easy to align with the original gear.
Old 12-03-2008, 02:21 PM   #4 (permalink)
4XLT's Avatar
4XLT wants to know Dino or Syn?
i had the 27 in mine before my build. loved it wasnt too much and was a great puller... i still have it if anyone needs one !
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
Vance & Hines Pro Pipe
4XLT is offline   Reply With Quote Quick reply to this message
Old 12-04-2008, 02:44 PM   #5 (permalink)
hardluk1 wants to know Dino or Syn?
I have a ev-23 in my 86fxr and am happy with .. Head covered it real well . Just gives a stronger bottom and midrange and still great milage at least for me. I ride in the nc mountains. You might want to upgrade the ignition??
hardluk1 is offline   Reply With Quote Quick reply to this message
Old 01-04-2009, 10:09 PM   #6 (permalink)
lucille wants to know Dino or Syn?
EV cams
'92 fxr, had two SE grinds in the past, now an EV27. Am happy with it, and would use it again.
lucille is offline   Reply With Quote Quick reply to this message
Old 01-05-2009, 07:49 AM   #7 (permalink)
Red02FXST wants to know Dino or Syn?
I put the EV 23 in my 87 two years ago. along with new SE 10:1 pistons
new lifters and stock push rods, valve job and CV off of a 2005.
Runs great now.
Kenny
Red02FXST is offline   Reply With Quote Quick reply to this message
