evo lifter grenades...
there is about 7,000 mile on this engine. S&S super stock cases, crane 310 high roller, edelbrock performer heads, S&S super e carb , drag pipes and you guessed it, points ignition. bought it from an old schooler who dies by points. bought the bike last fall and occasionally it would cut down on one cylinder like a misfire. it sat for a few seasons so i tuned it up over the winter (plugs wires amsoil all around and new points) and no miss for 2500 miles. i stopped at a redlight and heard some quick grinding and it was running on the rear cylinder. i limped it 1.5 miles to work and trailered it home. turns out the roller on the front intake lifter took out the cam and the lifter is jammed sideways in the tappet block. i checked out the rear tappet block and the intake lifter is missing the leg that holds the roller axle. i am guessing whoever did the mods didn't upgrade the lifters and pushrods as three of the pushrods were also bent slightly. anyway getting to the point, i am collecting the liifter pieces on the garage floor and im missing a few. is there any way to flush the oiling system w/o splitting the cases? i hop its not what i'm thinking... thanks for helping out a newb!
wildbill
