Oil Leak coming from the Volyage Regulator Plug : V-Twin Forum: Harley Davidson Forums
Old 03-18-2008, 08:31 AM   #1 (permalink)
bigobikerstuff is on a distinguished road
Why is there oil coming out of the plug where the voltage regulator plugs into the crank case on my 99 FXST EVO?????? And how do I fix it?
bigobikerstuff is offline   Reply With Quote
Old 03-18-2008, 09:28 AM   #2 (permalink)
bill corkey's Avatar
bill corkey is on a distinguished road
A common problem. There is a service bulletin from Hd recommending repositioning the connector so it is above the regulator. Search this site and you will find the problem covered very well.
edit: i went ahead and serched for the bulletin:
http://mysite.wanadoo-members.co.uk/...relocation.pdf
edit again: see also
http://www.v-twinforum.com/forums/tw...tml#post542877
plus there are other posts discussing cleaning the grommet and using various sealers. In my case, just getting rid of the valvolene synthetic and going back to hd primary oil stopped the leaking.
Bill
2011 TRI GLIDE merlot sunglo
and for fun a
2006 sportster roadster
bill corkey is offline   Reply With Quote
