09-11-2007, 11:38 AM
92 Evo blowing oil out of breather
My 92 Low Rider has just over 12,000 miles, and has never given me any trouble and has never leaked even a single drop of oil. The bike has been sitting for about the past 4 weeks though cause it's just too frikin hot to ride.
I started the bike over the weekend and had a frikin gusher of engine oil running out of my air cleaner. I removed the air cleaner and re-started the bike to find oil blowing out of the breather hose about 3 feet!
Any ideas? I can only imagine extreme crankcase pressure as the cause...
09-11-2007, 12:21 PM
Sumped
I do frickin believe that the frickin crankcase frickin filled with frickin oil, draining past the frickin pump from frickin being out of frickin service for that frickin period of frickin time.
Frickin check ball may frickin have to be frickin re-frickin-seated.
Frickin hope this frickin helps.
My frickin finger frickin wouldn't frickin stop frickin typing that frickin word. Help!
09-11-2007, 12:34 PM
Premium octane member
HP Inc 58/62 t/body 6.2gps injectors
TTS tuned by Jds Cycleworks
Black Boarzilla
Wood's TW9FG cams and KF325 filter
09-11-2007, 01:08 PM
Bet there ain't no oil left in the friggin bag.
09-11-2007, 02:06 PM
Oil Puking
I'll frickin bet your frickin right, Randy.
09-11-2007, 05:59 PM
 Frikin boneheads, thanks for the advice though...
09-12-2007, 11:21 AM
Hey Repo, Thoughs frikin guys could have atleast told tou that next time you go to start it after it sits awhile keep the gas off and crank it for a few, this can help to maybe move some oil and reset that frikin ball. (been there, did it)
09-13-2007, 02:49 PM
Thank you sir, appreciate the info.
09-22-2007, 10:10 AM
Hey are you guys all  Mexican?
09-27-2007, 09:23 PM
Milemarker 0
Had the same problem with my '90 Evo a couple of years back. Dealer told me to pull the dipstick then start the bike, which allowed the oil to be pumped back to the tank with no back pressure. Haven't had a problem since.
Dave
So what have we learned in the past two thousand years?
"The budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed lest Rome become bankrupt. People must again learn to work, instead of living on public assistance." ( Cicero , in 55 BC)
. . .Evidently nothing.
09-28-2007, 03:46 AM
I.A.T.S.E. Local 833
Well I can't wait to get home from work and try that. I've been getting oil splatter on the side cover, rear guard bag and side of the seat on my 98 evo for about two months. If thats all it takes to stop it I'll be ecstatic
Better People
Better Food
Better Beer
09-28-2007, 06:24 AM
Retired Navy - MCPO
98RKC,
Two completely different problems. Doubt it will solve yours.
Ed Y
2002 FLTRI
I yam what I yam.
09-28-2007, 07:29 AM
Originally Posted by Ed Y
98RKC,
Damn,
A guy can dream can't he
Any idea what would cause mine? I keep the oil level on the low side, and it just started getting bad within the last couple of months. May try the pad trick to see if that helps.
Better People
Better Food
Better Beer
09-28-2007, 10:40 AM
98RKC,
I'd be willing to bet the breather gear is starting to go south on you.
That plastic tooth POS.. who's brainchild was that anyway
I replaced my with the S&S reed valve breather and have had no problems.
09-28-2007, 01:16 PM
I would check the breather gear, I had two teeth broke off mine, was not blowing oil out but using it Qrt every 700-800 miles, replaced with S&S problem solved, this the firth thing the manaul tells you to check for several problems. Mine is a 98 FLHRC-I. 53,000 miles and runs great.
