SportbikeTrackGearFuel MotoBikeBandit Diamond Bar ChoppersMotorcycle.comCycleGear.comPowerstar Sparkplugs
Old 07-07-2007, 04:50 PM   #1 (permalink)
rlpos is on a distinguished road
Lifters
Anyone using these lifters from Revolution Performance. They call them Revperf "Hydro Rev". This it what they have to say about them. " These lifters feaure a unique hydraulic anti-pump up race retainer designed to precisely limit plunger travel and replace the cheesy OEM retaining clip. The roller and axle are manufactured of bearing quality carbon/chromium steel and feature needle bearings for ultra smooth rotation. The pushrod seat is carbo-nitrided for extreme durability and the lifter body itself is a high quality, super strong steel billet body, CNC machined for strength and durability. These lifters also carry a lifetime warranty! If the lifter ever fails we replace free of charge!"
rlpos is offline   Reply With Quote
Old 07-07-2007, 04:57 PM   #2 (permalink)
Average Dude
YankeeBob's Avatar
Yes, I am. Haven't had them on long (1500 miles). So far, so good.
Deut. 23:12-13
Old 07-08-2007, 11:30 PM   #3 (permalink)
harley92's Avatar
harley92 is on a distinguished road
how much does a set of these lifters cost
10+5+20+15-7=43
harley92 is offline   Reply With Quote
Old 07-09-2007, 05:25 PM   #4 (permalink)
there about 26 dollars each on their site
Old 07-09-2007, 05:33 PM   #5 (permalink)
2005 Road King Classic
bbrowncods's Avatar
bbrowncods is on a distinguished road
It is what is in my GMR build. Over 9000 miles on them.
05 Road King Classic - Sierra red pearl/Bassani Power Curve and Megaphones w/torque baffles/98" RevPerf BB/37g cam's/Stock 99B lifters/TTS/Stage 2 CNC'd heads by R&R(GMR) 9.7 CR/50mm Gerolamy Dual Throttle and filter/500cc injectors/Super Premium Oil Cooler/SE Clutch spring w/Easy-pull ramp and a bunch of this and that!
bbrowncods is offline   Reply With Quote
Old 07-10-2007, 07:39 PM   #6 (permalink)
Spectrex is on a distinguished road
I've heard they are good lifters, although the stock Harley lifters are fine for just about any build, even in my drag bikes. I've never had a problem with stock lifters and they cost a little less.
Spectrex is offline   Reply With Quote
Old 07-11-2007, 02:04 AM   #7 (permalink)
harley92's Avatar
are they relly worth changing .i have had problems with th oem liffters loosing presure over nigit once and a wile and some times when im running down the road.they are new oil presures great so i think its a falty lifter
10+5+20+15-7=43
Old 07-12-2007, 04:52 PM   #8 (permalink)
If you use the newer style OEM lifters, you won't have any problems with oil pressure or anything else. My bike's pressure is usually around 2-5 psi idling when it's really hot. That's plenty of pressure at idle. It'll get up to 25-35 while cruising.... also fine. If your lifters are bleeding down overnight, that's not a big deal either, as long as they pump up soon after starting the engine. Like I said before, OEM lifters are fine, even for race applications. I haven't changed the ones on my 1995 EVO in over 35k miles (except for one that the bearings crapped out on) and they are still working fine.
Old 07-12-2007, 04:56 PM   #9 (permalink)
bbrowncods's Avatar
Good except for the bearings...?
Old 07-13-2007, 01:09 AM   #10 (permalink)
harley92's Avatar
Cool
oil pressure is about 5-7 pounds at idle hot crusing ir 35 psi yes thats great pressure , im thinking of an oil cooler cause temps out hear can get as high as 115 average is 100 in the summer time so i think its cheap insurans to put one on cheapest iv fond so far is 200 bucks
10+5+20+15-7=43
Old 07-13-2007, 06:52 AM   #11 (permalink)
Lifters
We prefer ones made in the USA.
Old 07-13-2007, 07:52 AM   #12 (permalink)
harley92's Avatar
Cool
and how about starters or do you mean assmbled in the USA
10+5+20+15-7=43
Old 07-13-2007, 02:05 PM   #13 (permalink)
bonnie john is on a distinguished road
and they would be ?
bonnie john is offline   Reply With Quote
Old 07-13-2007, 07:54 PM   #14 (permalink)
harley92's Avatar
stock starters are not made in the usa
10+5+20+15-7=43
Old 07-14-2007, 12:40 PM   #15 (permalink)
All lifters can have problems with the bearings after putting many miles on them, frequency of oil changes, incorrectly adjusted pushrods, etc. I've only had two lifters fail because of the bearings, and this includes several Harleys I've owned over many years. Both had a LOT of miles on them, but I was still able to get home. One was a 1976 Sportster with solids. The pushrod loosened up and beat the heck out of the bearings, causing them to fail. The other was on my EVO and that lifter had over 40k on it, so it was bound to fail soon anyway. I also ride my bikes very hard, so they take more of a beating than most riders put on their machines.
