Originally Posted by mchaous
Hi,
I have a 1998 EG I just purchased. It has 69000 miles on it. I believe the motor was gone through and it seems to be fine. My problem is the carb spits/coughs back at low throttle like when you rev the engine at idle. I put a rebuilt carb “CVO” in with enhanced jets. Bike has screaming eagle ignition and breather. Has better pipes too. The bike runs fine except the cough every once in a while and I do get a lot of popping from the pipes when backoff in gear going down hills and such.
What else….The plugs are a little black but not too bad just a little. Funny the front plug is worse then the back. You would think it the other way. By the way I checked the compression and both are 93psi.
Any thoughts on how to get rid of the coughing?
thanks
Your low speed jet is too lean.
If it is a 42, go to a 45, and/or more, drill the welch plug out for your air idle and begin by setting the air idle screw at three turns.
This should help.
