EVO Style Head Bolts : V-Twin Forum: Harley Davidson Forums
Old 07-27-2012, 09:50 PM   #1 (permalink)
cacasal is on a distinguished road
Exclamation EVO Style Head Bolts
I have a 100" ULTIMA motor....( forget factory assistance...non existent... they only deal with their retailers and will not or can not give you a list of dealers in your area) .Broke a BEEHIVE style valve spring at just under 15,000 miles. Replaced them all with standard type springs ( designed for the high lift ) with inners and outers.
Reassembled motor and it ran great for 3 miles...BROKE all four long head bolts. I know I shouldn't have ...but I did re-use the old ones. Torque according to Ultima.....( FINAL TORQUE OF 42 FT lbs in 5 steps checking each step twice) Lubricated the treads with anti-seize
The long ones are the same as the stock ones on a 89 EVO, but the short ones are 1/4" longer than the stock ones.. Is there a stock bolt for any one of the family of H.D. motors that is the same as these short ones.
THEY ARE: 3/8 SAE thread( coarse ) ...1/2 " diameter and a length of 1.9"
I do not want to reassemble this with the original short bolts....even though they seem to be OK.
Any help/advise and /or moral support would be appreciated.
Carlos
I'd rather ride than wrench
cacasal is offline   Reply With Quote
Old 07-28-2012, 12:26 PM   #2 (permalink)
OUCH! That hurt
wfolarry's Avatar
wfolarry is on a distinguished road
Use the Twin Cam ones. 1.880
38 years of ridin' & wrenchin'
wfolarry is offline   Reply With Quote
Old 07-28-2012, 11:31 PM   #3 (permalink)
Thanks for the info......With that info, I made it to the H.D. dealer here in Reno and got every thing I needed.
Is it possible that TOO MUCH ANTI SEIZE trapped in the cavity left above the stud, heated to whatever the temp was when they broke, could have caused the weakening / fracture of the bolts.
All four broke within 30 seconds of each other. First the rear then the front. I realize that re-using the old ones was a bad decision on my part, but is it possible in your opinion that the anti seize could have contributed. I probably did use too much. This time it will be anti seize under the head of the bolt and a light oil film on CLEAN threads.
Thanks for your assist.
Old 07-31-2012, 02:42 PM   #4 (permalink)
OUCH! That hurt
wfolarry's Avatar
It's possible.
Old 08-01-2012, 01:48 AM   #5 (permalink)
tussuck's Avatar
tussuck is on a distinguished road
It's possible.... But I thought that you were only supposed to very lightly oil the bolts rather than use antisieze.
I prefer my engine Blown NOT Stroked!
Sent from my FXR powered iPad
I prefer my engine blown not stroked!
D.L.R.A #1174
tussuck is offline   Reply With Quote
Old 08-01-2012, 04:54 PM   #6 (permalink)
Anti seize?
[QUOTE=tussuck;2161651]It's possible.... But I thought that you were only supposed to very lightly oil the bolts rather than use antisieze. ]
My ULTIMA manual specifies either. Thanks
And I say thanks to those that took the time to respond....
Old 08-04-2012, 05:44 AM   #7 (permalink)
webco2 is on a distinguished road
There is a very interesting article on the LocTite website about clamping force and the use of thread lubrication on final torque settings.
webco2 is offline   Reply With Quote
Old 08-04-2012, 08:24 AM   #8 (permalink)
Thank you...I'll check it out.
Old 08-05-2012, 10:47 AM   #9 (permalink)
I looked but couldn't find it. Can you send a link? Thank you
Old 08-06-2012, 05:03 PM   #10 (permalink)
ok..all you EVER wanted to know about using nuts and bolts..lol..http://www.designnotes.com/companion/manual-1.html http://www.ehow.com/list_7425692_eff...que-bolts.html http://www.ehow.com/list_7425692_eff...que-bolts.html http://www.ehow.com/way_5180987_not-...ue-wrench.html if you need to change out your oil pressue sensor read this first.. http://www.ehow.com/how_5958330_use-...ue-wrench.html http://www.ehow.com/how_4927297_set-...ue-wrench.html
Old 08-06-2012, 05:07 PM   #11 (permalink)
Now that you have read all that..just clean bolts well, oil lightly, torgue in 4 steps, done.. http://www.portlandbolt.com/technica...que-chart.html A chart with most all torgue setting you will ever need... http://www.portlandbolt.com/faqs/ten...lained-sort-of ..Why we torgue bolts to start with..all in easy to understand language
Old 08-08-2012, 01:44 AM   #12 (permalink)
Great...Thank you....
