Help installing Ultima 53-644 digital ignition : V-Twin Forum: Harley Davidson Forums
Old 06-25-2011, 10:30 AM   #1 (permalink)
wjohnmax wants to know Dino or Syn?
Hi,
I have a 1999 Ultra cycles softail with a 113" S&S motor in it. My old stock ultra cycles ignition failed and I am replacing with the Ultima 53-644.
I cut the harness just above the old module and have exposed 4 wires..white, red, back and green...saving the plug above. These wires from the module plug into the harness where there is a green/white and red/ and black/white. The white and red has 12volts with the key and run stop switch on. I have run this to the central positive on the coil. I am installing the single fire...one coil option. My old coil was a dual fire with only two posts and two wires.
Now from the Ultima module I have the wire harness with white, pink, violet, green and blue.....so now what do I do. The instructions are a bit confusing to me? Thank you, John
wjohnmax is offline   Reply With Quote Quick reply to this message
Old 06-26-2011, 12:35 PM   #2 (permalink)
fastfatcow wants to know Dino or Syn?
off of ultimas inst. single fire single coil. violet to voes, green to tach, white to coil 12v, pink to coil neg rear cyl., blue to coil neg front cyl.
fastfatcow is offline   Reply With Quote Quick reply to this message
