High performance coil question : V-Twin Forum: Harley Davidson Forums
Old 02-23-2011, 02:49 AM   #1 (permalink)
07superglide wants to know Dino or Syn?
I have a 95 Anniversary Fuel Injected Ultra Classic and would like to add a high performance ignition coil..Anybody know of one that will fit this bike? part numbers?
07superglide is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 04:45 AM   #2 (permalink)
Dan89FLSTC wants to know Dino or Syn?
You will gain nothing by changing the ignition coil.
Dan89FLSTC is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 06:56 AM   #3 (permalink)
So your trying to tell me that more spark dosent help with easier starting,smoother idle,better throttle response,better gas mileage? Its all a myth? Hmm wander why they even make them?
Old 02-23-2011, 07:30 AM   #4 (permalink)
Iron Butt, SS2000
jerry34208's Avatar
jerry34208 wants to know Dino or Syn?
To get your money.
'04 Ultra built & tuned by Doc
'01 FXD built & tuned by Doc
Now if only I could learn to ride worth a sh!t...
jerry34208 is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 08:18 AM   #5 (permalink)
Originally Posted by jerry34208 View Post
To get your money.
Well i may be new to the Harley scene but have been doing mechanic work on autos for about 15 yrs,stock and performance.And have first hand experience that upgrades to the ignition system even if its only the coil does help..Maybe the ones ya'll have experience with or if you even do may be junk to begin with.
Old 02-23-2011, 09:58 AM   #6 (permalink)
DBChoppers's Avatar
DBChoppers wants to know Dino or Syn?
A good coil never hurts, Try Twin tec, Dyna or Compu Fire
Diamond Bar Choppers
(909) 861-8833
DBChoppers is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 05:33 PM   #7 (permalink)
Don`t confuse an aftermarket ignition system upgrade with a simple coil change.
An aftermarket system can give the advantage of better advance curves etc. Which can certainly give you performance improvements.
However, an aftermarket coil will give you no better performance than the coil already on the bike (assuming it is working properly).
Don`t be fooled by advertising for a coil that produces 87 gazillion megawattvoltjoules.
For example, lets`s say your spark plugs require 20,000 volts to fire. The energy in the coil will rise until it reaches sufficient voltage to cause the spark to jump the gap, 20,000 volts. The stock coil in your ignition system is already capable of producing more than enough voltage to fire the plugs.
Now slap on that fancy expensive aftermarket coil.
Now when the engine is running, the voltage in the new coil will rise until it reaches sufficient energy to jump the gap at, you guessed it, 20,000 volts.
I`ve been an aviation mechanic since 1974. I was taught this in Airframe and Powerplant school by an old man that seemed to know what he was talking about.
The answer to your second question, see Jerry`s post.
Old 02-23-2011, 07:16 PM   #8 (permalink)
qtrracer's Avatar
qtrracer wants to know Dino or Syn?
The stock Evo coil works very well as a matter of fact so does the SE ignition plug in box in that system. I had nothing but trouble when I went with the "best ignition system single fire vibration eliminator awesomest ever" thingamabob setup. The standard dual fire(the SE coil is fine if your old one takes a dump) with just the SE box is damn good, if you're worried that your coil may be less than optimum, buy a new one, the old one will never go bad when you carry a new one as a back-up.
"You have to inspire yourself. I am my own role model. I want to be me." Vincent Lepak 2008
qtrracer is offline   Reply With Quote Quick reply to this message
Old 12-20-2014, 12:14 AM   #9 (permalink)
Registered User
r750four wants to know Dino or Syn?
Ohhh God !!! Its not the spark plug that makes the decision when to fire, like when it see 20,000 volts ! and all coils are not created equal. When the ignition points open causing the condenser to discharge then the coil will fire,,, with whatever output voltage it is capable of producing. If the coil put out 50,000 volts then that is what the plug will get taking into consideration slight changes caused by plug wire resistance. Variations in the primary and secondary windings of the coil have an effect on the output voltage and current. The fewer the windings and the larger the wire in the primary side causes more current and the more wraps of thinner wire there are in the secondary side of the coil causes higher voltage output to your plug which in turn gives you a stronger spark!!!! This is why coils are rated for application based on primary resistance. If you use the wrong coil with the wrong primary resistance for you type of ignition system you will cause premature failure of your ignition module/ points/ and plugs. Most high performance coils boast a 10,000 volt gain over stock and that is great for better ignition over longer plug gaps and they do this by increasing the number of wire wraps in the secondary side of the coil which in turn can cause the coil to run hotter and not live as long as a stock one. Just remember to stay within stock spec when it comes to the primary resistance when upgrading a coil.
r750four is offline   Reply With Quote Quick reply to this message
Old 12-20-2014, 05:43 PM   #10 (permalink)
RLH3175's Avatar
RLH3175 wants to know Dino or Syn?
I've been involved with motorcycle drag racing for 25 years, have never seen any improvement in power in after market coils.
We have witnessed a shift in thinking about government from one that serves at the pleasure of citizens and to do their bidding, to one that considers its role to manage the populace,
RLH3175 is offline   Reply With Quote Quick reply to this message
Old 12-24-2014, 11:02 PM   #11 (permalink)
rhd47 wants to know Dino or Syn?
4 years later.........wunder what the OP did......hummmm..?
The Alpha and The Omega
" Don't Forget To Put Your Feet Down When You Stop "
rhd47 is offline   Reply With Quote Quick reply to this message
Old 12-25-2014, 11:21 AM   #12 (permalink)
olddad64 wants to know Dino or Syn?
high output coils
I put a Accell Super Coil on my 08 FXD Super Glide and I don't know if it helped or not. Bike runs great and never had any problems . It's been on for couple years or more. I do know from experience that a High Performance Coil on a car/truck engine makes a big difference so why not on a motorcycle.
olddad64 is offline   Reply With Quote Quick reply to this message
Old 03-06-2015, 12:05 PM   #13 (permalink)
Jeff F. wants to know Dino or Syn?
After testing the resistance and replacing my old plug wires, I tested the spark with the tester set at 1/2" and my 20 year old OEM coil threw a dark purple spark that I hope I never get to touch. I can't imagine ever needing more zap than that.
Jeff F. is offline   Reply With Quote Quick reply to this message
Old 03-10-2015, 05:46 PM   #14 (permalink)
>>> The Curmudgeon <<<
barrybasinger wants to know Dino or Syn?
For he benefit of anyone that may be reading this old thread: A simple coil change will do NOTHING for an otherwise near-stock bike--particularly an EFI engine. The stock coil works well. I use them on all my EFI bikes, all the way up to near 11:1 compression and 100 horses.
A new coil is the last thing I ever worry about. By the way, the EFI coil and the carb coil are not the same.
BB
You may find this interesting:
https://sites.google.com/site/harleyrealstreet/
Five Simple Rules:
- Free Your Heart From Hatred
- Free your Mind From Worries
- Live Simply
- Give More
- Expect Less
"Livin' Dreams and Makin' Memories"
Brian C. Basinger 1944 - 2011
R.I.P., Bro'
barrybasinger is offline   Reply With Quote Quick reply to this message
Old 03-10-2015, 05:58 PM   #15 (permalink)
>>> The Curmudgeon <<<
Again, for the benefit of anyone reading this years after the OP: I'm gonna split hairs here, but in fact the spark plug (in combination with the surrounding conditions) does determine the instant at which the plug will fire.
When the available voltage reaches the point needed to jump the gap under said conditions, the coil will discharge and the plug will fire.
If the required voltage is 25k volts, the plug will fire at that value, and if the required voltage is 50k volts due to a very large gap, super high-compression, extremely turbulent chambers, or whatever, then the plug will fire at that point.
A coil voltage greater than that required to jump a plug gap at any given point is wasted capability (and money). It is not the maximum theoretical voltage capability of the coil that is controlling things here, it is the plug gap, chamber pressure, etc. In other words, it's what's needed to fire the plug, not some overly-impressive marketing-derived number that one sees in the advertising in magazines.
Like I said, spliting hairs...
BB
Five Simple Rules:
- Live Simply
- Give More
- Expect Less
R.I.P., Bro'
