Head Porting a 80 inch???? : V-Twin Forum: Harley Davidson Forums
Old 12-26-2009, 11:38 PM   #1 (permalink)
gsxrboy96's Avatar
gsxrboy96 wants to know where he is and how he got here
Ok, so im building a 80 inch evo for my bagger, the only set in stone thing i have so far is a set of stock bore 10 to 1 je pistons and screaming eagle 1.7 primary chain kit ill be installing. Lets say i throw in a woods w6 with this set up with stock heads, what hp/tq numbers would i see, then what if i have mild port/polish done, What are the gains gonna be?? ive read several places where they say stock valve size and port size is sufficient, then ive read elsewhere where they say chamber and port is horrible and should be modified. whats your guys input?? and has anyone done back to back test to verify gains over stock vs ported heads??? thanks chad.
gsxrboy96 is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 06:20 AM   #2 (permalink)
Site sponsor, Rosa's Cycle, recently tuned and 80" Evo, with a Wood 6, and a good* set of heads, equipped with V&H Big Radius pipes, and the dyno results showed 85 hp and 93 ft/lbs!!!!!!!!!
Scott
Old 12-27-2009, 09:16 AM   #3 (permalink)
gsxrboy96's Avatar
Scott
scott, i know its hard to say, but what if the heads were left alone? what kinda power do you think that bike woulda made?
Old 12-27-2009, 11:37 AM   #4 (permalink)
kennyflhr's Avatar
kennyflhr wants to know Dino or Syn?
Scott
Think it would have done a little better with a thunder header?
kennyflhr is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 11:49 AM   #5 (permalink)
98 FLHX's Avatar
98 FLHX wants to know Dino or Syn?
+1....any decent 2:1, for that matter.
"Si Vis Pacem, Para Bellum"
______________________
10:1 JE Pistons
Heads by GMR Performance
Ness Big Sucker
Mikuni HSR 42
V-Thunder 3040 Cam
Dyna 2000 Ignition
Thunderheader
_______________________
98 FLHX is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 12:06 PM   #6 (permalink)
60195 wants to know Dino or Syn?
Still does not address the original question of a Woods 6 cam, 10.1 compression and untouched oem heads. Has anyone dyno'd this combination?
60195 is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 12:17 PM   #7 (permalink)
gsxrboy96's Avatar
thats exactly what im looking for, or back to back with stock heads vs ported heads?
Old 12-27-2009, 12:30 PM   #8 (permalink)
kennyflhr's Avatar
I hear ya Ed! Looks like my "head" money may be spent on new bushings & motor mounts! That's why I got in. For some reason I seem to want my bike to stop & turn now. In the old days it was just go fast! Must be getting old!LOL
Old 12-27-2009, 05:21 PM   #9 (permalink)
Cheapdad wants to know Dino or Syn?
I went from cam, carb, intake, ingition--first step. Second step, boosted compression and "street port"...my builder said it was not really a port/polish...but "a 5 angle valve job is yesterday--I just added to the valve job a little cleaning things up, which is all your build on an Evo needs". ADDED: dyno at 71/75 prior to compression/heads
the headwork cost me $275...when added to the compression bump, it's a very responsive and satisfying ride! AND with old style SE (cycle shack) slip ons.
My target was torque, broad power band, reliable...a "riding bike" for Idaho backroads.
advice? spend a little more for 1 step over stock heads...don't do a full-tilt port and
polish.....and ride, ride...
Cheapdad
1998 Lowrider
80 inch, mikuni 42, Andrews 27, Cycle Shack
9.75 compression, SE pistons, street port
Cheapdad is offline   Reply With Quote Quick reply to this message
Old 12-27-2009, 06:53 PM   #10 (permalink)
Chad, there is some good comparisons here:
http://www.nightrider.com/biketech/hplist_evo80.htm
NOt exactly what you are looking for, but provides some insight.
Old 12-27-2009, 07:43 PM   #11 (permalink)
gsxrboy96's Avatar
yea, ive seen that, did you seen where he made 95 hp on a unported head?
Old 12-27-2009, 08:09 PM   #12 (permalink)
Seems like a bit of a stretch.
Old 12-27-2009, 09:20 PM   #13 (permalink)
I do believe it can be done....but not in a consistent way. My builder thinks God made the Evo heads...which leads to his "cleaning up" my heads and not going with a more focused port/polish.
Night Rider list also shows the necessity of matching the components...notice the stock heads are listed with 80 inchers when the compression is stock--up to the low 9's. Above 9.5 and almost everything reflects something done with the heads.
In my humble opinion, the "formula" of matched parts has a huge impact on the final product.
....stopping and turning also sounds like a very good goal in my view! (52 y.o.)
Cheapdad
1998 Lowrider
Old 12-28-2009, 12:48 AM   #14 (permalink)
kennyflhr's Avatar
funny how that creeps up on ya! 20 years ago it just wasn't that important.(43)
Old 12-28-2009, 05:49 AM   #15 (permalink)
Have never done back/back here to compare.
Scott
