Easiest way is to clamp one side of the crossover tube, cut it, and put a larger tube over the other end and drain fuel into a gas can.
The stealer sells the stock clamps to redo....make sure to clamp the right side before installing tank, then do the left.
I prefer these over standard hose clamps.
