Motorcycle-Communication
RRcycles.comDan Vance RacingCustom DynamicsAmerican Side Road CycleAdvanstarMotorcycleShowsCycleGear.com
JardineProducts.com
Old 10-25-2009, 12:52 PM   #1 (permalink)
Cheapdad is on a distinguished road
woods 6 vs 8...optimal build
just thinkin'..........
for you Woods fans: what would you consider the optimal builds for the 6 and the 8 cams, assuming an 80"....and reliability? (I've heard horror stories about boring Evo cases)
what kind of headwork carb, pipes, compression, ignition, oil cooler, intake...
and what would the dyno show on each build?
...and, if you feel like typing---same discussion with your 2 preferred Andrews cams?
--and where does reliability start to go downhill?
Cheapdad
Cheapdad
1998 Lowrider
80 inch, mikuni 42, Andrews 27, Cycle Shack
9.75 compression, SE pistons, street port
Cheapdad is offline   Reply With Quote
Old 10-26-2009, 07:00 AM   #2 (permalink)
Iron Will
Hillside's Avatar
You are planning on boring the cases, to bring a larger engine to the picture??
Scott
Old 10-28-2009, 08:36 PM   #3 (permalink)
I'm concerned about boring the cases...and having a negative impact on reliability and engine life....maybe just stories?
Also--not after a drag racer..long days in the mountains at 45-65 mph suit me best...and with gas in my area, I need to keep the compression under 10:1.
So..If I plan to keep the 80 inch (slip on 85s?) and compression under 10:1...relilability, rideability...with an occasional "roll it up", what build combo gets the most, before sacrifices start?
OR..am I just BSing myself--and I shoud give into the Bigger is better gang?
Cheapdad
Cheapdad
1998 Lowrider
Old 10-29-2009, 07:16 AM   #4 (permalink)
Iron Will
Hillside's Avatar
A Wood 6 at 10:1, will easily show 80 hp/90 ft/lbs.
A Wood 8 set at 10.7-8 will be at 90/90, time after time.
Head mods are needed to establish this power.
Scott
Old Yesterday, 07:54 AM   #5 (permalink)
choppers
Question
Scott
Scott
what are the real advantages about the intake valve size bigger??
the edelbrock RPM has
in 1.940
ex 1.625
the edlebrock performer has
in 1.850
ex 1.610
these heads have 72cc both.
will be used with the W6H.
one more question :
the stock starter will work with 10:1 ????
thanks in advance
choppers
chico
choppers is online now   Reply With Quote
