Leave the 107" as is , and re-work the heads, install a Wood 98, or 9F cam, bore the G carb, and install a Thunderjet.
Along with a Dyna 2000i ignition, and a Supertrapp 2/1 with about 20-24 disc's, would have you realizing that you did it correctly once tuned!!!!
Scott
