Motorcycle-CommunicationDiamond Bar ChoppersMotorcycle.com Classifieds!Bub EnterprisesProCharger.comPro PadSportbikeTrackGearAmerican Side Road CycleMBO Enterprises
Old 10-13-2009, 12:23 PM   #1 (permalink)
beuch70 is on a distinguished road
cylinder heads
got a 1990 fxr and will my heads come off without pulling the motor,thanks
beuch70 is offline   Reply With Quote
Old 10-13-2009, 12:26 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
Yes they will.
I suggest pulling the front motor mount/bracket and carefully lowering the motor down while still keeping it supported. Also, you may need some cut off allens and improvised tools. Tight fit, but they will come off. I just did a set of base gaskets on one last week.
Axtell 117 cyls and pistons
Mikuni HSR48
S+S Super D manifold
Black Boarzilla
Old 10-13-2009, 01:24 PM   #3 (permalink)
Originally Posted by TXCHOP View Post
Yes they will.
i want to get the heads redone,bigger vavles and open them up
Old 10-13-2009, 01:25 PM   #4 (permalink)
Iron Will
Hillside's Avatar
That helps them, done correctly.
Scott
Old 10-13-2009, 01:46 PM   #5 (permalink)
Scott
hiilside what do you change to do a set of heads,bigger vavles,open them up cc them.what size vavles sould i go with.its a 89 in with a s&s 561 cam,super e carb,9-5 comp,think im goin to use .30 headgaskets to up the compression
Old 10-13-2009, 07:57 PM   #6 (permalink)
Iron Will
Hillside's Avatar
beuch70,
Check your pm box.
Scott
