Originally Posted by ridingonlife
I have a 1996 ultra classic I just purchased with 36,000 miles. It has streight pipes. Going in with a andrews e-27 cam, ajustable push rods, 2 into 1 thunder header and a power commander ignition system. what hp jump should I expect.
At those miles if the lifters have not been changed, you may want to inspect/replace, as per a Moco service bulletin stating such at 25,000 miles.
Also, at the point of the upgrades, re-surfacing the cylinder heads, -.060", will REALLY bring the whole thing togather.
Scott
