The cam that came in the bike was a Red Shift, but too big for what I need. I put in a Comp Cams with the power band in a more realistic range.
I knew HD made two general styles of pinion gear, 1993 and newer and 1992 and older. I didn't know there were different cam gears, other than the diameter of the camshaft where the gear presses on.
I'm not sure that pressing on a stock HD cam gear will work. It's been too long since I had a stock cam in to know the stock ID of the gear. I ordered the Comp Cams cam without gear hoping to press on a Crane Cams gear that I already have. The inside diameter of the Crane gear is too small to fit the Comp Cams shaft, so I ordered a gear from Comp. Somewhere I read that Comp Cams uses the red gear, so if that is true then something is not quite right here. Could be Comp, could be Crane. Maybe someone with weigh in and let me know which one is the red headed stepchild.
I have a couple of gauge pins coming in, but they aren't a lot of use without knowing what the original cam was, or either the stock pinion gear size that was mostly used. As with the red cam gear, if I knew which pinion gear was normally installed I can go down a size or two.
I had hoped that HD mostly put in a certain pinion gear and I could order one a couple of sizes smaller to shorten the down time. Looks like I will have to mike it when the gauge pins come in and then order a smaller one.
