Bub Enterprises
Motorcycle.com Classifieds!CycleGear.comRRcycles.comFuel MotoMotorcycle-CommunicationAdvanstarMotorcycleShowsProCharger.comMBO EnterprisesCustom Dynamics
Old 09-08-2009, 09:31 AM   #1 (permalink)
Talledaga Al is on a distinguished road
Bob Wood 43.5 Rebel 80 evo
I've have a 91 softtail that i built this spring. just started to jump on it and it's a rocket! The heads have been ported and flowed, i run 10 to 1 wiseco's, wood w6h cam, dyna 2000. but i'm toren with leaving the stock cv carb or moving up to a rebel 43.5 ? $$$ not sure if it's to much for this 80 ci? I can pull my buddies stroked fxr till 110 mph if i dont miss 4th gear! think i lean out at the point? running a 190 jet w/ dyno jet kit that was installed years ago. for a soft tail that looks stock i'm happy, but this motor want to run, it pull at 80 to 90 mph like i can't believe, but like everyone else i want more! love to see 90 to 100 hp, any help out there? like to learn how to start a new thread? sorry for jumping on this one.
'91 FXSTC
80 cu. evo.
weisco 10 to 1
woods w6h cam
Dyna 2000 dual fire
woods 43.5 rebel carb
Talledaga Al is offline   Reply With Quote
Old 09-08-2009, 09:41 AM   #2 (permalink)
beuch70 is on a distinguished road
come on...........
beuch70 is offline   Reply With Quote
Old 09-08-2009, 09:50 AM   #3 (permalink)
Iron Will
Hillside's Avatar
That carb, with a Wood 8 cam, set @ 10.7-8 will show you those numbers in an 80" Evo, as long as the heads/tune are good.
Scott
Old 09-08-2009, 10:14 AM   #4 (permalink)
I really like this cam and hate to change it, and your right about torque. This is a street bike and big hp numbers don't matter, it's how well it runs on the street that matters! i'm just debating whether to tune the cv which is a newer style carb or upgrade It? If I leave it on, I might replace the slide to a stock size hole and upgrade the needle with one of woods.
'91 FXSTC
80 cu. evo.
weisco 10 to 1
woods w6h cam
Dyna 2000 dual fire
Old 09-08-2009, 12:00 PM   #5 (permalink)
Iron Will
Hillside's Avatar
Most all Wood cams are torque-biased grinds.
Scott
Old 09-08-2009, 01:25 PM   #6 (permalink)
Scott, Whats your opinion of the 43.5 over the stock cv carb? would you work the stock carb or upgrade it? I had Robertson's upgraded the valves and flowed the heads. Jimmy said they flowed really well, he mentioned that i'd need to change carbs. I like the cv style carb and he's infavor of the S&S E carb.
'91 FXSTC
80 cu. evo.
weisco 10 to 1
woods w6h cam
Dyna 2000 dual fire
Old 09-08-2009, 01:39 PM   #7 (permalink)
4XLT's Avatar
4XLT is on a distinguished road
think about the Mikuni 42 also it would work well with yoru setup!
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
4XLT is offline   Reply With Quote
Old 09-09-2009, 05:43 AM   #8 (permalink)
Iron Will
Hillside's Avatar
The Wood carb is one hellava carb, and it'll run circles around the OE cv.
Mike makes a valid poit as well, in suggesting a 42 Mikuni.
THe S&S may run almost as good, but have witnessed that carb consume more fuel doing so.
Scott
Old 09-09-2009, 08:37 AM   #9 (permalink)
Thanks for the info ! I'll have to save up for a new carb/intake.
'91 FXSTC
80 cu. evo.
weisco 10 to 1
woods w6h cam
Dyna 2000 dual fire
Old 09-09-2009, 01:32 PM   #10 (permalink)
4XLT's Avatar
the Mikuni will slip onto your stock manifold, not sure you would need a larger one for your application, i found my Mikuni on Ebay at a decent price....
98 FLHT
93" S&S Stroker kit
Mikuni 42
1.90 int 1.625 ex
Wood W6-H cam
Old 09-09-2009, 04:11 PM   #11 (permalink)
TheNowhereman's Avatar
you want 100hp out of that 80 incher, no problem.
Just don't get the 42 mik.
Get a 45 mik instead.
Now you guys stop barking and listen up
I have run an 80 inch evo for years.
dual plug heads, red shift, and a 45 mike THAT I had to jet up to get it perfect.
Still gave me 35 around town.
It also put out 104 hp and was completely streetable.
A 42 will not cut it with decent head work and a bump stick with above .500 at the valve.
Your compression is just right for the street.
A good header is a requirement for good HP an torque specs so take a look at that also.
100hp 80 inchers are real an reliable.
Nowhereman who else?
Old 09-09-2009, 04:25 PM   #12 (permalink)
Iron Will
Hillside's Avatar
Totally agree with the 100 hp, 80", as we have been there, in that part of town, many times as well.
Scott
Old 09-09-2009, 04:51 PM   #13 (permalink)
ROY YOUNG is on a distinguished road
Here ya go! Approximately 30K miles
2009 BMW R1200GS Adventure
1996 Ultra Classic
1978 FLH
ROY YOUNG is offline   Reply With Quote
Old 09-09-2009, 05:08 PM   #14 (permalink)
4XLT's Avatar
i'm going to have to find someone with a 45 Mik and see if i can get better than my 100hp out of it ... hmmmmm
98 FLHT
93" S&S Stroker kit
Mikuni 42
1.90 int 1.625 ex
Wood W6-H cam
Old 09-09-2009, 07:29 PM   #15 (permalink)
rcsoftail is on a distinguished road
Added a mikuni 42 to a similar build years ago. Huge difference versus the stock cv. Not familiar with the 43.5 rebel carb.
rcsoftail is offline   Reply With Quote
