JekillandHyde.euMotorcycle.com Classifieds!Diamond Bar Choppers
Bub EnterprisesSportbikeTrackGearCycleGear.com
CycleGear.com
Old 09-03-2009, 05:43 PM   #1 (permalink)
Will-Run is on a distinguished road
How much hp+tq.?
On an s&s 107t motor with blended chambers, mild port work,
tightened up squish, 030 head gasket, 10:25:1 comp, w6h cam,
Dyna single fire,twin coil ign. Mik 42, wood 325 ac, V&H Pro pipe
and a good tune. ( Jarz Dyno ). What would be a realistic expectation for hp & tq for this?. I picked up the motor with 1600 mi
on it and am putting it in my FXR. I know I could go more extreme
but I need tractable motor.
Thanks, much appreciated.
Will-Run is offline   Reply With Quote
Old 09-04-2009, 07:56 AM   #2 (permalink)
lionsm13 is on a distinguished road
I would think that 90-100 HP and TQ would be a reasonable expectation.
What was you thinking?
IT's ALWAYS SOMETHING!!
lionsm13 is online now   Reply With Quote
Old 09-04-2009, 08:45 AM   #3 (permalink)
KingofCubes's Avatar
The R&R headed 107 that we produce will average 120 torque and horse with the smaller choked down ports very nice street manors in a Dyna.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 09-04-2009, 11:29 AM   #4 (permalink)
I was hoping around 110 & 120
Old 09-04-2009, 01:28 PM   #5 (permalink)
rcsoftail is on a distinguished road
I have a 106" with mik 42, 10.5:1 comp, s&s600 cam and r&r heads. I haven't had it on the dyno yet, but my previous numbers when it was an 88" was 95tq. I would estimate I now have an additional 20+tq. Not familiar with the woods cam, but somewhere around 115 sounds reasonable.
rcsoftail is offline   Reply With Quote
Old 09-04-2009, 02:43 PM   #6 (permalink)
4XLT's Avatar
4XLT is on a distinguished road
you should be very close to the numbers you are looking for, it's all in the heads, if you look at my build with hillsides work on the heads, and tune i am getting just over 100 hp and a bit over 105 tq..
i woudl think if the heads are matched to the cam and you get your compression up around 10.5:1 you shoudl be able to achieve 110 hp easy... proper tune and a good pipe will be needed also..
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
4XLT is offline   Reply With Quote
Old 09-06-2009, 02:39 PM   #7 (permalink)
speedfreak is on a distinguished road
hp ft.
i think you can expect arond 110 rwhp and arond 120ft.
my stock s&s v107t deliver 105 rwhp and 106ft in the superflow
cycle dyno bench. i have the v&h pro pipe on mine to.
regards speed.
speedfreak is offline   Reply With Quote
Old 09-10-2009, 07:05 AM   #8 (permalink)
Iron Will
Hillside's Avatar
As he stated, he has S&S heads, with a Wood 6H.
Back on track now, and to answer the question, certainly believe that 110/120 is well within reach, set-up, and tuned correctly, with peak torque coming on VERY early, and spool up extremely quick as well.
Old 09-10-2009, 06:04 PM   #9 (permalink)
Thank you. since posting, I've decided to have Baisley do the port work on my S&S heads
while keeping the stock valve diameters. Any further comments on this setup would be
much appreciated.
