08-30-2009, 08:52 PM
Mikuni HSR 42
Hey Scott.
Will a Mik42 feed an S&S 107-T with headwork, cc ed, tightened up squish, 10:1 static with Wood 6h, If one stays a grand south of 6.?.
I'm looking for awesome throttle response.
Thank you much for your time and wisdom.
08-30-2009, 11:24 PM
I am running a hsr42 on my 106 with r&r heads, 10.5:1 compression and s&s600 cam. It runs great. Moved the needle up one clip, using a 170 main jet and a 60 accelerator pump. I am sure I would get a little more wide open throttle power if I had a hsr45, but already had the hsr42. Everything except for wide open throttle should be the same between the hsr42 and hsr45 due the nature of a flat slide. If you have a choice, go with a hsr45, but I wouldn't spend the money if you already got the hsr42.
08-31-2009, 03:40 AM
Would you recommend the HSR 42 or 45 on a 80 with screamin eagle headwork.
(Don't know exactly what other headwork but the motor has 80 HP and 74 ft lbs torque)
08-31-2009, 06:08 AM
Iron Will
Originally Posted by Will-Run
Hey Scott.
That carb will handle that engine, as long as peak hp numbers are not a large concern.
Scott
08-31-2009, 01:48 PM
I think the hsr42 is a nice size for an 80 incher, even with head work.
08-31-2009, 02:26 PM
mine works well
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
08-31-2009, 05:47 PM
Scott
At what rpm with this motor, would the 42 become the stopper?.
09-01-2009, 06:51 AM
Iron Will
I'd bet that it would show signs of it at 5300-5500 on that 107", but usually that is enough anyway.
Scott
09-01-2009, 08:00 AM
02 RK,S&S 124" Evo
Think about how many times you would be revving your motor into the 5500 rpm range.Most of us ride well below that,unless challenged.Even then our Harley motors are torque monsters,my belief is without mega cubes, optimize what you have for the riding you do the most.Too big a carb will hurt off idle performance.
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
09-01-2009, 07:16 PM
Solid truth.
Thanks.
09-02-2009, 10:55 AM
You'll get decel popping coming out of your ass but, it will work with normal riding habits.
Better just get the 45 and be done with it.
 Nowhereman who else?
09-02-2009, 10:23 PM
Can you please explain why decel popping would be worse with a smaller carb? I am experienceing decel popping with my MIK 45 right now.
