RRcycles.comFuel MotoDiamond Bar ChoppersCycleGear.comJardineProducts.comCustom DynamicsSportbikeTrackGearAdvanstarMotorcycleShowsBub Enterprises
Extreme Custom Engraving
Old 08-28-2009, 07:30 PM   #1 (permalink)
Ron99 is on a distinguished road
Flywheel Recommendations
Looking to do a 96" stroker on my 99 evo. Is there anything wrong with the Ultima crank assemblies vs say an S&S? This is not a strip type bike. More of a local bar hopper. The S&S rods look beefier but the Ultima claim a stronger ligsht weight material. Any difference in the balancing? Could I run S&S stroker big bore pistons? Would rebalance be required or only reccomended?
Ron
Ron99 is offline   Reply With Quote
Old 08-28-2009, 09:00 PM   #2 (permalink)
TonyJ's Avatar
TonyJ is on a distinguished road
You should look into the price of a whole new S&S motor. For what flywheels, pistons, con rods, pinion shafts, new cylinders or boring your old one, boring your cases, gaskets and labor is going to cost you, for not much more, you could have a 113.
And when you bore that evo to get to 96inches, the material between the cylinders on the cases gets mighty thin. I know its done alot, but I dont like it.
You get what you pay for with Ulitima. Some have OK luck with them, but I went that route once, will never do it again.
If its just a bar hopper and you want more power on the cheap, change the gearing.
Because We All Know, Stock Sucks!!
TonyJ is offline   Reply With Quote
Old 08-29-2009, 10:39 AM   #3 (permalink)
Thanks for the inout. From what I've read the late cases are OK to bore, its the early cases that had the issues. From a labor standpoint I'll be doing most of the work. That's why I asked about the balancing. That I would send out. Would really like some opinion of the Ultima vs S&S crank assemblies. I've heard the "get what you pay for" line before but from what I've seen Ultima makes some pretty sweet motors. Any experience out there on this?
Old 08-29-2009, 08:28 PM   #4 (permalink)
rcsoftail is on a distinguished road
I am running a S&S crank spin balanced by R&R in my 106" If it is a solid mount motor in a softail it is definately worth the spin balancing to keep the vibration down. I personally would not purchase an Ultima. I have heard too many bad experiences with their stuff.
rcsoftail is offline   Reply With Quote
Old 08-30-2009, 06:23 PM   #5 (permalink)
johnsachs
Ultima's will last as long as,and are as good as the others.You should have NO problems.
John
johnsachs is offline   Reply With Quote
Old 08-31-2009, 08:10 AM   #6 (permalink)
dsvracer is on a distinguished road
I have used plenty of the Ultima and S&S lower ends. have had good results with both. If you decide to use the S&S crank they will balance it to the new pistons you are using for "FREE". Just give them the weights of the parts (pistons, rings, pins and clips) when you order the flywheels and they will send you the lowerend balanced. The 96" Evo motor is a real nice motor. Plenty of useable power in all gears at any rpm. With a good set of heads and a nice cam getting over 100 torque and hp is pretty routine. i can help if needed. dsv
www.danvanceracing.com
Dan Vance Racing
641 Brook Rd
Hampton Ct. 06237
Authorized S&S dealer
2001 AHDRA National Championship Pro-Gas
18 Final round appearances 15 wins
Torque is quick horsepower is fast !!
dsvracer is offline   Reply With Quote
Old 08-31-2009, 08:44 AM   #7 (permalink)
Iron Will
Hillside's Avatar
Agree with John, but S&S does have a very good product as well.
Scott
Old 08-31-2009, 12:31 PM   #8 (permalink)
Thanks for the feedback. Your experience says volumes.
