If you currently have S&S heads you are almost stuck with using their pistons because of their funky chamber shape. There are options, replace the heads, then run whatever you want, or weld up the heads and run whatever you want. If you have any other heads besides S&S you can run pistons from almost everyone. Wiseco, Keth Black, CP, Axtell/JE , Arias all make very good pistons for the Evo 96".
And FYI - 96" evo stroke is 4 5/8".
Ed
