Custom Dynamics Leslie Kay'sStainless Ride Specialty AccessoriesDiamond Bar Choppers
Old 08-25-2009, 06:15 PM   #1 (permalink)
Who Cares
any4xx is on a distinguished road
No timing set on EFI Evo?
I've got a '98 FLTRI. To me, it seems down on power. The fact that I can run regular gas on a 115 degree day and lug the crap out of it without any pinging tells me I don't have enough timing in it. Or am I out to lunch here? The only engine mods are an Andrews EV27 cam and Wiseco 10:1 forged pistons.
So anyway, I break out the service manual and proceed to check the timing. First I discover that it is an impossible task without the clear timing cover, so that is on order. But I went ahead and screwed with the clocking of the timing plate just to see what it would do. And it did NOTHING. I went as far as to completely remove the studs and turn the thing as far as I could in both directions and it did nothing to the engine speed. So I'm assuming that the engine computer only wants a signal form that plate and does ALL of the timing adjustment??? I have a PC-III USB and I know I can alter the timing from that, but I would have thought that rotating the timing plate would have done SOMETHING.
Any thoughts?
any4xx is offline   Reply With Quote
Old 08-25-2009, 09:39 PM   #2 (permalink)
1997bagger's Avatar
1997bagger is on a distinguished road
It is possible your overfueled causing low power and not able to make it detonate, an EV27 (36 intake closing) and 10:1 should be easy to make detonate.
On the timing plate, moving the plate 1/8" clockwise made a difference in timing on mine, I had problems with detonation (high ccp) at roll-on and controled it with a 12.8 afr but was at the edge of overfueling, moved the plate and able to tune to 13.5 or 13.2 afr and finally had consistant power without detonation.
Moving the plate made a difference on mine but it is a bandaid repair until I remove some compression but I think you have an afr problem and would head in that direction and use the plate as a last resort.
1997bagger is offline   Reply With Quote
Old 08-25-2009, 11:39 PM   #3 (permalink)
Who Cares
I had it dyno-tuned at sea level at 13.8. I'm at 6,000' now, but I can't imagine that the altitude here could richen it even a full point. I'm sure there is a way to figure the A/F ratio change at various elevations, but I sure don't know how.
Old 08-26-2009, 04:12 PM   #4 (permalink)
If you had it tuned at 0 ft and you're at 6K ft now, yeah, that's your problem. It appears that the HD EFI system is fairly stoopid on setting the base MAP level for baro correction (which I kinda doubt is in there at all). At altitude, I have no problem outrunning twinkies, and I suspect that's why. A tuned twinky has trouble staying up with the Sporty at high altitudes, but runs real strong down where it was dyno'ed. My wife's Megasquirted Sportster has dual MAP sensors with baro correction.
Dr.Hess
http://www.drhess.net
"71"
Old 08-26-2009, 04:54 PM   #5 (permalink)
Who Cares
Yeah. I called Dynojet this morning and got the scoop. It's as easy as reducing all the map cell values by the same percentage. I knocked 15% off of everything and it seems to run fine now. Early HD fuel injection is ALMOST as good as a carburetor.
Still waiting to hear if someone knows about the timing issue.
Old 08-26-2009, 05:50 PM   #6 (permalink)
I'm not familiar with your particular setup, but:
1. You don't need a clear timing plug to check the timing. You just set the bike upright, remove the steel plug from the case and expect to get some oil mist blown out. Not a lot, but enough to wear eye protection and not have your car parked next to it when you have it running.
2. If your EFI system has a idle speed valve, that will likely be controlled by the computer so that if you are fiddling with the ignition timing, the computer could be fiddling with the idle valve to keep the speed the same.
3. Set the timing where it's supposed to be and don't F with it. Fix your fuel maps for your altitude, which you seem to have a handle on.
Dr.Hess
"71"
Old 08-27-2009, 10:33 AM   #7 (permalink)
1997bagger's Avatar
I was trying to be suttle about the timing plate movement but this paragraph is what I was thinking.
Old 08-27-2009, 12:09 PM   #8 (permalink)
Who Cares
Well as it turns out, the plate IS set in the fixed position by design and has no effect on ignition timing on the FI models. I dug farther back into the service manual and found it referenced in the FI section instead of the ignition timing section. So if the FI guys WANTED to alter timing, they (we) would have to do it through the Power Commander anyway, as there's no way to alter timing except through computer manipulation. But now that I've got my A/F ratio dialed in by the SOTP method, the bike is running well.
Old 08-27-2009, 12:10 PM   #9 (permalink)
Who Cares
Oh, and Dr. Hess: What's a "Twinkie?"
Old 08-27-2009, 02:55 PM   #10 (permalink)
Beemervet's Avatar
Beemervet is on a distinguished road
Originally Posted by any4xx View Post
What's a "Twinkie?"
It's a term of affection used for any Twin Cam engined bike.
Beemervet is offline   Reply With Quote
Old 08-27-2009, 07:47 PM   #11 (permalink)
Otto is on a distinguished road
the cam sensor on a magnetti evo just tell the efi which cylinder is on compression timing is done off the crank just like a TC the only way to change timing is with your pc or tuning software
Otto
Workin to play
Otto is offline   Reply With Quote
Old 08-28-2009, 10:49 AM   #12 (permalink)
1997bagger's Avatar
My timing retard is maxxed with a PC3 and have some roll on detonation, turned the plate 1/8" counterclockwise and it rattled so bad I turned around, moved it to center and 1/8" clockwise and could remove fuel and add some timing in areas.
Otto, I respect anything you do, moving the plate did help me out.
Old 09-02-2009, 01:05 AM   #13 (permalink)
but if your timer plate on a efi evo is in the slots and not in the 2 holes it is incorrectly installed and causing the system to run in a default setting. depending on which timer cup it has installed.
Otto
Workin to play
Old 09-03-2009, 10:03 PM   #14 (permalink)
1997bagger's Avatar
Uni-bit, origional 2 holes.
Otto, I understand what you are saying, Chevy 5.7, solid distibuter set on #8 and ecm takes over timing.
Maybe the ecm cannot change the timing enough (retarded) with the cam sensor backed off. The ecm could be in default mode but no noticable performance problem.
I have a Wego 3 with DA logging and the plate move is the best it has ever run and achieving 13.5 roll on for the first time without detonation. I will pull the heads this winter and relieve some air out of it for the correct repair.
Otto, I understand Diesel and Automotive ecm's and their parameters (27 year diesel tech). Educating me on Harley ecm's won't offend me, you learn by listening and making mistakes.
