RRcycles.comCycleGear.comFuel MotoMotorcycle-CommunicationDiamond Bar ChoppersBikeBandit
MBO Enterprises
Old 08-11-2009, 08:12 PM   #1 (permalink)
mvent is on a distinguished road
Pushrod?
Can stock pushrods be used with S/E perf heads pn 16854-98A with an andrews ev27 cam and 030 head gaskets?
mvent is offline   Reply With Quote
Old 08-11-2009, 08:17 PM   #2 (permalink)
--Doof 43--
Serg06's Avatar
Serg06 is on a distinguished road
Get a set of rods that can be taken out without messing withe the rocker box's. If your o-rings seals leak your going to wish you had.
Serg
06 Street Glide (Sheala) 124" S&S
Super sucker A/C
True Duals.
THE SCORE:
Asphalt=1
Me=0
Serg06 is offline   Reply With Quote
Old 08-11-2009, 09:03 PM   #3 (permalink)
The EV27 has the same base circle as a stock cam so the stock pushrods should work. If the pushrod tube o rings leak you can cut the stock pushrods with bolt cutters and then install the adjustable pushrods.
Old 08-12-2009, 11:31 AM   #4 (permalink)
Thanks for the suggestions, as long as stock 1 piece will work I'd rather use them for lightness and honestly hate adjusting them.
Old 08-12-2009, 01:54 PM   #5 (permalink)
Iron Will
Hillside's Avatar
You may want to measure the thickness on the cylinder head casting. 3.750" is stock.
Anything less than that, and your going to have to run a shorter, fixed length, or an adjustable.
S&S is the flavor we prefer.
Scott
Old 08-12-2009, 04:37 PM   #6 (permalink)
econnor is on a distinguished road
Get the good stuff.
The best pushrods are made by Smith Bros. They make pushrods primarily for NASCAR and other racing teams, but they also make pushrods for Harley engines. Checkout their website, everything you want to know about pushrods.
www.pushrods.net
Part # AHD79SB-EVO-FI, they are $30.00/ea
econnor is online now   Reply With Quote
Old 08-12-2009, 04:45 PM   #7 (permalink)
Great info, will def measure head casting, do the math and order appropriate length pr's
Old 08-13-2009, 12:25 AM   #8 (permalink)
wanna ride's Avatar
wanna ride is on a distinguished road
Actually there's nothing tothe adjusting, just spin back wheel until oposite lifter is just starting to go up and set the opposite pushrods to manufacturers instructions on amount of turns and then move onto the next, simple.
2002 FXDWG
1989 FLHTP
Lynn
wanna ride is offline   Reply With Quote
Old 08-13-2009, 05:48 PM   #9 (permalink)
any cam change you want to put adjustables in always gonna need them high lift means adjusting valves
Old 08-13-2009, 09:08 PM   #10 (permalink)
OUCH! That hurt
wfolarry's Avatar
wfolarry is on a distinguished road
SE heads are .060 shorter than stock. Plan on adjustables. Or custom length ones from Smith's.
35 years of ridin' & wrenchin'
wfolarry is offline   Reply With Quote
Old 08-13-2009, 09:12 PM   #11 (permalink)
--Doof 43--
Serg06's Avatar
S&S adjustable. Now go buy some.
Serg
Super sucker A/C
True Duals.
THE SCORE:
Asphalt=1
Me=0
Old 08-13-2009, 09:18 PM   #12 (permalink)
Smith Bros makes adjustable pushrods and EZ install pushrods for EVOs. The EZ install rods are $30 each and are built very well.
Old 08-14-2009, 01:49 PM   #13 (permalink)
Ok thanks, adjustables it is !
