07-20-2009, 03:20 PM
Clutch ideas
ok now that i am pushing 105+ lbs of tq, i know not allot compared to most of the builds going on now, but for a stock clutch with over75K on it i have noticed under full power going threough the gears...
i am going to try and adjust it ( doesnt look too difficult in the manual)
but over the winter i'd like to replace with a good clutch i knwo nothing about them, are the lock up kinds ?
i seen in the twinkie section a VPP ? or a Scorpion ?
need some recomendations. any help would be great...
onsn, stock belt will also be changed out this winter
98 FLHT
93" S&S Stroker kit
Mikuni 42
heads Hillside valve job port and polish.. 200 ccp
1.90 int 1.625 ex
Wood W6-H cam
DynaTech 2000 ignition
big sucker with zippers big filter
D&D Fat Cat ... fast black
07-20-2009, 06:21 PM
Iron Will
Mike,
A Rivera Pro-Clutch would be a viable option to consider.
Scott
07-20-2009, 06:51 PM
thanks Scott i'll check them out tonight..
any specific spring pressure to look for? or just a pro clutch for an evo ?
98 FLHT
93" S&S Stroker kit
Mikuni 42
1.90 int 1.625 ex
Wood W6-H cam
07-20-2009, 07:33 PM
mooooving out!
105 ft lbs is enough to start breaking things. not too shabby.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
07-20-2009, 08:11 PM
I ran a stock clutch + SE spring and VPC and it hed real well. Recetly changed out to Energy One Extra plate clutch + SE spring + VPC and it's strong.
Rivera is set up is even better.
FXDRYDR
2003 FXD
98" Small Bore
107HP/113TQ
07-21-2009, 12:50 PM
i had a SE spring put in when i did the build...
ya 105 lbs and that was on a bad air day on the dyno, so i figure on good days itrs a bit more,,,
the thing thats so hard on everythign thos is its a 750lb bike adn i'm pushing the 400lb mark so i know things are going to break if i dotn keep up with them lol
was hopping the clutch will last til winter is all. as i am not working presently.
i looked at a few options yesterday and i will probably go pro clutch when the time comes..
98 FLHT
93" S&S Stroker kit
Mikuni 42
1.90 int 1.625 ex
Wood W6-H cam
07-21-2009, 04:02 PM
02 RK,S&S 124" Evo
I think I would try the spring update first.Personally have the Scorpion in both my bikes,the reason, because Barnett has been around for a long time.Good Luck
06 RK,155" R&R TwinCam
02 RK,124" S&S Evo
07-23-2009, 11:00 AM
clutch
take a look at the barnett extra plate clutch kit and a stronger spring, they work great hold alot of power and are "relatively" inexpensive. thats what i am running and so far so good.
07-23-2009, 12:10 PM
Barnett, Bandit, and Rivera will all take care of your clutch issues.
You arent making enough HP to need a lock up type hat so don't spend the extra money on it.
FORMER STREET RACER
MULTIPLE HARLEY RACE WINNER
8 TIME DYNO SHOOTOUT WINNER
2 TIME BEST OF SHOW WINNER
07-23-2009, 01:01 PM
thanks folks.. i was thinking about adding a plate and stuff but figured with the miles on might as well go new and better.. thanks PW i hadnt heard allot about the lockup types, i didnt think i would need it, not 150 hp or drag racing every weekend ... mostly just cruising and some street racing here and there..
98 FLHT
93" S&S Stroker kit
Mikuni 42
1.90 int 1.625 ex
Wood W6-H cam
